Greetings to all. Been trying to get the water leak sensor to transmit notifications but haven't been successful. Anyone know how to make this happen?
Insteon Water leak Sensor Notifications not working
there are other posts here about setting up an event action to email or text.
are you seeing the leak sensor status change when it gets wet? this of course is the trigger for the eventMark
HS3 Pro 4.2.19.5
Yes, the leak sensor status changes to wet, and then the i/o linc controlling the water valve does close. When I dry the leak sensor and then click the sensor to clear it, the i/o linc does open the valve to let the water source continue as normal. I just don't get any notifications. I do have gmail setup and have tested it on other devices and get notifications.
See this post in your previous inquiry for creating an Event which should send an email notification. https://forums.homeseer.com/forum/hs...73#post1570273
If you don't have an Event set up to send the notification, you must do this first. HS4 does not send any 'automatic' notifications; you have to configure which actions will create a notification.
If you've created an Event correctly, and the sensor has become wet, the HS4 log should show the Event Trigger, and another entry for the email sent. If properly configured, your Gmail account should also show the email in Sent Items.
Are you sending this email to an email-to-text service (i.e. @vtext.com or similar for other carriers)? Verizon's vtext service is notorious for not working well, or having significant delay.
I got it working, it was the email, setup and I had to restart the computer so I'm good now. Thanks for everyone's help, I just need to do them as individual events for the 11 leak sensors so I can get an alert for the specific leak sensor that has detected the leak as oppose to a general message stating a detected leak.
if you search hs support for replacement variables, you can use them in the email body to get status of all the sensors at once
here is an example of an email body i use to get the status of all the window sensors in a room if any of them trigger the event.
Left window: $$DSA:Vista Zone 19:
Right window: $$DSA:Vista Zone 20:
Bathroom window: $$DSA:Vista Zone 21:
Side window: $$DSA:Vista Zone 9:Mark
HS3 Pro 4.2.19.5
- Likes 1
