System: HS4 w/ Zwave and Insteon plugin
Using Insteon hub 2245-222
Approx 30 Insteons and 6 Zwave devices
all devices working since July, 2022
1 day ago Insteon devices stopped responding to HS and Alexa commands with the following exceptions:
2 insteon bulbs stil work 100%
1 insteon lamp controller responds to on command via event on run but not event off run. Will not respond via device command
Insteon devices previously on Insteon hub before server shutdown stil respond normally
All Insteon devices will respond at local device level
Detailed log indicates no error
All comms checked out at 100%
steps taken,
Reset plug ins (even though no issues noted)
Restarted HS system, no change
Recent device change:
replaced Insteon toggle switch and 2 linked lamp modules with equivalent Zwave plus devices. New devices working as expected
Also, I had not read the post concerning not removing Insteon devices loaded to HS and deleted those mention above in the zwave swap out, my bad. I deleted the events first, then the devices.
Ideas/Suggestions (note, I am a HS newbie
