I'm right testing this plugin and when I try retrieve e.g. a temperature value from my modbus controller using hs.DeviceValue(ID) I will get an integer number. According to HS manual this returns an integer. However, when I look at the device settings I can see this temp value as a decimal number so I'm wondering how can I retrieve the value as a decimal number.
Edit: Another question. I have 3 controllers with Modbus interface which are daisy chained so they have IDs 1, 2, 3. I haven't added these yet to modbusSeer so how can you define the ID?
