New problems with modbusSeer
  • salvesen
    hey, thanks for the info! I will make 1 default, it makes sense that this should have a default value.
  • jlikonen
    I managed to solve this problem. I deleted the TCP master and the devices and recreated all of them. I hadn't given a value for the multiplier because I thought 1 is a default value. Now I gave this value and my devices are working. I don't know how to read a 64bit register so I created four devices, one for each Modbus register. This seems to work.
  • jlikonen
    started a topic New problems with modbusSeer
    Hi, I'm now reading modbus registers from an ABB electricity meter B23. For example quantity active import is in reg 5000 (hex) and it is in 4 regs. Each register is 16 bits. I have first setup my TCP master and then added a new device. MB register 5000 (hex) corresponds to 20480. Basically I want to read 64bit data from this register. It didn't work. I then tried to create new devices, one for each register so I have 4 devices. None of them works. Debug log is:
     [TABLE="class: log_table_row"]
    [TR]
    [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]helmi-05 12:51:55 [/COLOR][/TD]
     			[TD="class: LogPri1, align: left"] [/TD]
     			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Debug [/COLOR][/TD]
     			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Read adress: 5000 with name: Sähköauton lataus kWh value: -0.001 [/COLOR][/TD]
     		[/TR]
    [/TABLE]
    [TR]
    [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]helmi-05 12:51:55 [/COLOR][/TD]
     			[TD="class: LogPri0, align: left"] [/TD]
     			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#000000]Debug [/COLOR][/TD]
     			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Catched at readHoldingRegister: System.InvalidOperationException: Nullable object must have a value. at System.ThrowHelper.ThrowInvalidOperationException(ExceptionR esource resource) at HSPI_modbusSeer.serial.modbus.readHoldingRegister(ModbusClie nt client, addDevicesPageResponse slave) [/COLOR][/TD]
     		[/TR]
    [/TABLE]
    [TR]
     			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Catched at readHoldingRegister: System.InvalidOperationException: Nullable object must have a value. at System.ThrowHelper.ThrowInvalidOperationException(ExceptionR esource resource) at HSPI_modbusSeer.serial.modbus.readHoldingRegister(ModbusClie nt client, addDevicesPageResponse slave) [/COLOR][/TD]
     		[/TR]
    [/TABLE]
    [TR]
     		[/TR]
    [/TABLE]
    [TR]
     		[/TR]
    [/TABLE]
    [TR]
    [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]helmi-05 12:51:56 [/COLOR][/TD]
     		[/TR]
    [/TABLE]
    It looks like modbusSeer tries to read register 5000 so is the hex value for the register. When adding a new device I put 20480 for the holding register. Similarly for the next devices with registers 20481-20483. I'm sure my modbus is working because I also used Modbus Master software and I can read the registers without any problems. Any ideas?
