I have an event turning a hue light on at 6am. The log indicates the event ran but the light doesn't go on. If I run the event manually, the light goes on.
Time Triggered Event
This is what was in the log:
9/4/2020 6:00:00 AM HomeSeer Device Control Device: Plugin PhilipsHue Color Control to (0)
9/4/2020 6:00:00 AM HomeSeer Device Control Device: Plugin PhilipsHue Brightness to 55% (55)
9/4/2020 6:00:00 AM HomeSeer Device Control Device: Plugin PhilipsHue Status to On (1)
9/4/2020 6:00:00 AM HomeSeer Event Event Trigger "Night Lighting BR Lamp 1"
I didn't realize there's a trace for log and one for log file. I set the log setting to trace and changed the event to run at 1 pm. By the way, running the event manually works fine.
The trace log is too big to attach but here's some of it:
9/4/2020 1:00:06 PM PhilipsHue Trace {"5":{"state":{"on":true,"bri":194,"hue":51705,"sat":162, "ef fect":"none","xy":[0.3212,0.2083],"ct":153,"alert":"select","colormode":"hs","mode":"homea uto mation","reachable":true},"swupdate":{"state":"noupdates","l astinstall":"2020-08-11T19:51:45"},"type":"Extended color light","name":"Hue Master","modelid":"LCT012","manufacturername":"Signify Netherlands B.V.","productname":"Hue color candle","capabilities":{"certified":true,"control":{"mindiml evel":2000,"maxlumen":450,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"candlebulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:83:c1:0 3-0b","swversion":"1.50.2_r30933","swconfigid":"A9AFB57A","p ro ductid":"Philips-LCT012-1-E14ECLv1"},"6":{"state":{"on":false,"bri":254,"hue":33214,"s at":140,"effect":"none","xy":[0.2611,0.4276],"ct":153,"alert":"lselect","colormode":"hs","mode":"home aut omation","reachable":true},"swupdate":{"state":"noupdates"," lastinstall":"2020-08-24T19:18:02"},"type":"Extended color light","name":"Hue Lamp","modelid":"LCA003","manufacturername":"Signify Netherlands B.V.","productname":"Hue color Lamp","capabilities":{"certified":true,"control":{"mindimlev el":200,"maxlumen":800,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"sultanbulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:97:19:f c-0b","swversion":"1.65.11_hB798F2","swconfigid":"4A7D1A15", "p roductid":"Philips-LCA003-1-A19ECLv6"}}
9/4/2020 1:00:06 PM PhilipsHue Trace Response:StatusCode: 200, ReasonPhrase: 'OK', Version: 1.1, Content: System.Net.Http.StreamContent, Headers:
Connection: close
Pragma: no-cache
Pragma: no-cache
Access-Control-Max-Age: 3600
Access-Control-Allow-Origin: *
Access-Control-Allow-Credentials: true
Access-Control-Allow-Methods: POST, GET, OPTIONS, PUT, DELETE, HEAD
Access-Control-Allow-Headers: Content-Type
X-XSS-Protection: 1; mode=block
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
Content-Security-Policy: default-src 'self'
Cache-Control: no-store, must-revalidate, no-cache, post-check=0, pre-check=0
Date: Fri, 04 Sep 2020 18:00:07 GMT
Server: nginx
Referrer-Policy: no-referrer
Content-Type: application/json
Expires: Mon, 01 Aug 2011 09:00:00 GMT
9/4/2020 1:00:06 PM PhilipsHue Trace Request:Method: GET, RequestUri: 'http://192.168.1.216/api/bSb7-qeHEiTAhTDA3oY4HPYjhsStaY1-80nDdHTM/lights', Version: 1.1, Content: , Headers:
9/4/2020 1:00:00 PM PhilipsHue Trace {"5":{"state":{"on":true,"bri":194,"hue":51705,"sat":162, "ef fect":"none","xy":[0.3212,0.2083],"ct":153,"alert":"select","colormode":"hs","mode":"homea uto mation","reachable":true},"swupdate":{"state":"noupdates","l astinstall":"2020-08-11T19:51:45"},"type":"Extended color light","name":"Hue Master","modelid":"LCT012","manufacturername":"Signify Netherlands B.V.","productname":"Hue color candle","capabilities":{"certified":true,"control":{"mindiml evel":2000,"maxlumen":450,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"candlebulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:83:c1:0 3-0b","swversion":"1.50.2_r30933","swconfigid":"A9AFB57A","p ro ductid":"Philips-LCT012-1-E14ECLv1"},"6":{"state":{"on":false,"bri":254,"hue":33214,"s at":140,"effect":"none","xy":[0.2611,0.4276],"ct":153,"alert":"lselect","colormode":"hs","mode":"home aut omation","reachable":true},"swupdate":{"state":"noupdates"," lastinstall":"2020-08-24T19:18:02"},"type":"Extended color light","name":"Hue Lamp","modelid":"LCA003","manufacturername":"Signify Netherlands B.V.","productname":"Hue color Lamp","capabilities":{"certified":true,"control":{"mindimlev el":200,"maxlumen":800,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"sultanbulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:97:19:f c-0b","swversion":"1.65.11_hB798F2","swconfigid":"4A7D1A15", "p roductid":"Philips-LCA003-1-A19ECLv6"}}
9/4/2020 1:00:00 PM PhilipsHue Trace Response:StatusCode: 200, ReasonPhrase: 'OK', Version: 1.1, Content: System.Net.Http.StreamContent, Headers:
Connection: close
Pragma: no-cache
Pragma: no-cache
Date: Fri, 04 Sep 2020 18:00:01 GMT
Server: nginx
9/4/2020 1:00:00 PM PhilipsHue Trace Request:Method: GET, RequestUri: 'http://192.168.1.216/api/bSb7-qeHEiTAhTDA3oY4HPYjhsStaY1-80nDdHTM/lights', Version: 1.1, Content: , Headers:
9/4/2020 1:00:00 PM PhilipsHue Trace [{"success":{"/lights/5/state/hue":51705}},{"success":{"/lights/5/state/sat":162}},{"success":{"/lights/5/state/bri":194}}]
Connection: close
Pragma: no-cache
Pragma: no-cache
Server: nginx
9/4/2020 1:00:00 PM PhilipsHue Trace {"bri":194,"hue":51705,"sat":162}
9/4/2020 1:00:00 PM PhilipsHue Trace Request:Method: PUT, RequestUri: 'http://192.168.1.216/api/bSb7-qeHEiTAhTDA3oY4HPYjhsStaY1-80nDdHTM/lights/5/state', Version: 1.1, Content: Q42.HueApi.Models.JsonContent, Headers:
Content-Type: application/json; charset=utf-8
9/4/2020 1:00:00 PM PhilipsHue Trace {"5":{"state":{"on":true,"bri":139,"hue":42830,"sat":104, "ef fect":"none","xy":[0.2887,0.2951],"ct":153,"alert":"select","colormode":"hs","mode":"homea uto mation","reachable":true},"swupdate":{"state":"noupdates","l astinstall":"2020-08-11T19:51:45"},"type":"Extended color light","name":"Hue Master","modelid":"LCT012","manufacturername":"Signify Netherlands B.V.","productname":"Hue color candle","capabilities":{"certified":true,"control":{"mindiml evel":2000,"maxlumen":450,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"candlebulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:83:c1:0 3-0b","swversion":"1.50.2_r30933","swconfigid":"A9AFB57A","p ro ductid":"Philips-LCT012-1-E14ECLv1"},"6":{"state":{"on":false,"bri":254,"hue":33214,"s at":140,"effect":"none","xy":[0.2611,0.4276],"ct":153,"alert":"lselect","colormode":"hs","mode":"home aut omation","reachable":true},"swupdate":{"state":"noupdates"," lastinstall":"2020-08-24T19:18:02"},"type":"Extended color light","name":"Hue Lamp","modelid":"LCA003","manufacturername":"Signify Netherlands B.V.","productname":"Hue color Lamp","capabilities":{"certified":true,"control":{"mindimlev el":200,"maxlumen":800,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"sultanbulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:97:19:f c-0b","swversion":"1.65.11_hB798F2","swconfigid":"4A7D1A15", "p roductid":"Philips-LCA003-1-A19ECLv6"}}
Connection: close
Pragma: no-cache
Pragma: no-cache
Server: nginx
9/4/2020 1:00:00 PM PhilipsHue Trace [{"success":{"/lights/5/state/bri":139}}]
Connection: close
Pragma: no-cache
Pragma: no-cache
Server: nginx
9/4/2020 1:00:00 PM PhilipsHue Trace {"bri":139}
9/4/2020 1:00:00 PM PhilipsHue Trace {"5":{"state":{"on":true,"bri":217,"hue":42830,"sat":104, "ef fect":"none","xy":[0.2887,0.2951],"ct":153,"alert":"select","colormode":"hs","mode":"homea uto mation","reachable":true},"swupdate":{"state":"noupdates","l astinstall":"2020-08-11T19:51:45"},"type":"Extended color light","name":"Hue Master","modelid":"LCT012","manufacturername":"Signify Netherlands B.V.","productname":"Hue color candle","capabilities":{"certified":true,"control":{"mindiml evel":2000,"maxlumen":450,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"candlebulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:83:c1:0 3-0b","swversion":"1.50.2_r30933","swconfigid":"A9AFB57A","p ro ductid":"Philips-LCT012-1-E14ECLv1"},"6":{"state":{"on":false,"bri":254,"hue":33214,"s at":140,"effect":"none","xy":[0.2611,0.4276],"ct":153,"alert":"lselect","colormode":"hs","mode":"home aut omation","reachable":true},"swupdate":{"state":"noupdates"," lastinstall":"2020-08-24T19:18:02"},"type":"Extended color light","name":"Hue Lamp","modelid":"LCA003","manufacturername":"Signify Netherlands B.V.","productname":"Hue color Lamp","capabilities":{"certified":true,"control":{"mindimlev el":200,"maxlumen":800,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true ,"p roxy":true}},"config":{"archetype":"sultanbulb","function":" mixed","direction":"omnidirectional","startup":{"mode":"safe ty","configured":true}},"uniqueid":"00:17:88:01:08:97:19:f c-0b","swversion":"1.65.11_hB798F2","swconfigid":"4A7D1A15", "p roductid":"Philips-LCA003-1-A19ECLv6"}}
Connection: close
Pragma: no-cache
Pragma: no-cache
Server: nginx
9/4/2020 1:00:00 PM PhilipsHue Trace [{"success":{"/lights/5/state/on":true}}]
Connection: close
Pragma: no-cache
Pragma: no-cache
Server: nginx
9/4/2020 1:00:00 PM PhilipsHue Trace {"on":true}
9/4/2020 1:00:00 PM HomeSeer Device Control Device: Plugin PhilipsHue Color Control to (0)
9/4/2020 1:00:00 PM HomeSeer Device Control Device: Plugin PhilipsHue Brightness to 55% (55)
9/4/2020 1:00:00 PM HomeSeer Device Control Device: Plugin PhilipsHue Status to On (1)
9/4/2020 1:00:00 PM HomeSeer Event Event Trigger "Night Lighting BR Lamp 1"
I don't see any problem in this log, the bridge reports that command was successfull and lights #5 is on:
Code:9/4/2020 1:00:00 PM PhilipsHue Trace [{"success":{"/lights/5/state/on":true}}]
the only potential problem is that the color control command might override the brightness value you set previously because internally when setting a color the plugin converts it from a RGB value to a HSV value, and a HSV value means Hue, Saturation and Brightness values will be set.
So either remove the brightness command, or move it after the color control.
