spud Would it be possible for the plugin to create devices for scenes that are associated with the bridge? The device would need a feature that would allow for either activating or deactivating the scene manually.
What I'd like to do, using Easy Trigger, is push a scene to a stack and then be able to pop it from the stack to restart the scene. This way I could pause the current running scene, replace it with another action or scene for a duration, and then revert back to the original scene.
Use case: During the holidays my front outdoor lights are displaying a holiday scene. If someone opens the front door or if motion is detected, I could push the running scene to a stack, brighten the front lights and change their color to bright white (either using another scene or with normal HS actions), wait 3 minutes, and then pop the original scene from the stack to restore the original scene.
Would this be possible without too much trouble on your behalf?
Also, do you foresee Transitioning Scenes (where bulbs rotate through changing colors) being supported once you upgrade the plugin to the Hue V2 API?
--Barry
--Barry
