I have been using the smartthings plugin for about a week. The device control works fine (on/off) but the other devices associated with the appliance are not updating. Looking at the logs, it also seems to have additional sensors available that have no devices created in Homeseer. I have logs available but did not want to publish on the forum incase they contain keys etc.
Smartthings devices not updating
Originally posted by ozinnewy View PostI have been using the smartthings plugin for about a week. The device control works fine (on/off) but the other devices associated with the appliance are not updating. Looking at the logs, it also seems to have additional sensors available that have no devices created in Homeseer. I have logs available but did not want to publish on the forum incase they contain keys etc.
In my case the audio volume is not updating for my Smart TV.
Also the mute is not updating.
John
Originally posted by spud View Post
Set the log level debug and check if the volume level and mute status is sent to the plugin. According to another user it wasn't so if it is true, there is not much I can do. https://forums.homeseer.com/forum/hs...77#post1381977
"audioVolume":{"volume":{"value":22,"unit":"%","timestamp":" 2020-11-19T12:29:58.529+0000"}},
But in all cases it will have a value of "22".
John
I have the same problem with an aeotec smart switch 7, it takes quite some time for the device in homeseer to update
Even turning the device on/off in homeseer makes the device react direct but the status update in homeseer takes several seconds.
status change in homeseer takes about 25 seconds
Originally posted by akatar View PostI have the same problem with an aeotec smart switch 7, it takes quite some time for the device in homeseer to update
After sending a command the plugin wait 500ms and poll the device for status, this delay may not be enough and you probably get the old status, so that the new status is only retrieved on the next polling cycle. You can change the polling interval for each device by clicking on the device and going to the SmartThings tab. At the bottom of this page there is a polling interval field you can change.
I guess everything is using the cloud and not direct to the hub?
I'm sorry but i have another question
i added a smartthings aeotec water sensor and i have in homeseer also now a "thing"??
Definition:
{ "deviceId": "368827c7-55b7-469f-8a08-7d5553586a5a", "name": "Thing", "label": "Thing", "deviceManufacturerCode": "LUMI", "locationId": "acab4d4e-eeac-4cba-9d42-16dcdd9bba33", "deviceTypeId": "0144b700-9df5-4f06-9bfe-7a5d056b8aac", "deviceTypeName": "Thing", "deviceNetworkType": "ZIGBEE", "components": [ { "id": "main", "capabilities": [] } ], "dth": { "deviceTypeId": "0144b700-9df5-4f06-9bfe-7a5d056b8aac", "deviceTypeName": "Thing", "deviceNetworkType": "ZIGBEE", "completedSetup": false, "networkSecurityLevel": "UNKNOWN", "hubId": "d0322a0e-ca31-47a3-933b-e77b72a0f670" }, "type": "DTH" }
any idea what this is?
