I just added my first 3 HS200 switches. They are all set up and on the same subnet as the homeseer hometroller sel2, each with a reserved IP address. When I installed the plugin, I tried to discover the devices, and I didn't see any show up, then I tried logging into to Kasa, didn't see any there, then gave the plugin an IP address, and saw this error in the logs:
error in getDevices() err:Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
Any thoughts? TIA
Any thoughts? TIA
