Hi there,
Are there any plans to enable this plugin to trigger smarts defined in Tuya?
In all honesty, to date I've addressed discovered shortcomings in native Tuya plugin devices/behaviours (specifically, controlling IR devices) by way of defining Tap-to-Run Smarts in Tuya app to execute the desired sequence of button presses, then used HS IFTTT plugin to indirectly trigger them.
Since IFTTT has just switched to 3 applet limit on free a/cs, this recourse now no longer low hanging fruit.
That said, were a Tuya Smart be able to be triggered from HS4 event, that would neatly alleviate need for IFTTT and offer benefits to any other use cases that may possibly utilise Tuya Smarts.
Do very much recognise and appreciate that getting all my home automation business logic onto the "one page" in HS my ultimate desired objective, but until plugin perfected, enabling trigger of Tuya Smarts would be an extremely valuable addition (as well as significantly improving its possible utility!).
Many thanks for your ongoing work and kind regards
