Testing this plug-in with 1 Tuya enabled device (light dimmer SW2 by Gosund) only.
Good news first. Plug-in is really easy to setup. It recognized my Tuya dimmer instantly and created 4 HS3 devices.
What is not so good is
1. KISS. Why so many devices for a simple dimmer. Single device with value from 0 to 100 would be enough. 0 would be OFF and anything else ON with the relative brightness.
2. "Dim" slider doesn't work. The light doesn't follow the dim adjustments made at HS.
3. No feedback to HS. If dimmer is manually operated on/off or dim - neither one change shows at HS. Light would be manually OFF and it will show as ON in HS.
None of the above problems appears at Tuya app.
