Guys, if you have devices that work in the Tuya App but not in the Tuya plugin then there is a procedure to do so, so spud can add them to the plugin.
Here is a procedure. If anyone can add something I forgot please do so. TIA
Please create an event which contains the devices in question. Go into the plugin Tuya 4.0.34.0 Beta and in Settings turn on logging to Trace. Run the event. In the Logs sub-dir in HS4 there is a file called Tuya.txt. If you can make a zip file out of it then post it here. If you can't make a zip file then place the Tuya.txt file here in your post. Make sure to address your post to Spud so he can see all these txt or zip files in one place. Thanks all.
