Velux KLF200 plugin information
    This plugin allows you to use a VELUX KLF200 gateway to discover and control your VELUX INTEGRA / io-homecontrol (Somfy) devices like window openers, shutters, blinds, and more in your HomeSeer system.
    • Control Velux, Somfy, and other io-homecontrol-compatible products
    • e.g. VELUX INTEGRA window blinds, awnings, openers
    • VELUX KLF200 controller (with LAN connection)
    ​Usage is hopefully self-explanatory - the plugin detects the devices set up in the KLF200 gateway and creates corresponding HomeSeer devices to control them and to report their status.
    The user manual is attached: VeluxKLF200 plugin.pdf
    This is great! Now the only thing for me is to be able to get a hold of a KFL200 for less than $500 Cnd.
      Yes, it's shame they aren't going to publish the API for the new Active gateway, which is much cheaper and only seems to lack the physical input options. I asked Velux directly and the answer was basically no, the Active is a consumer product which they won't open up officially.
      I'm also not completely convinced the Active is free of needing web connectivity, which is a security blocker for me.
        Nice, I'll give this a try next week when I'm able.
        Question - how do you handle the disconnects with the KLF that seem to happen every couple days?
        At the moment I use python scripts to execute programs on the device, and every few days it fails to respond, so I have a plug I cycle to restart it.
        Am I the only one this happens to, or are you able to periodically soft-boot it from the plugin?
          I had the same problem when using scripts, I think because the gateway isn’t good at releasing badly closed connections.
          the plug-in is very stable, I haven’t had any connection issues in months.
          I included a plug-in function to run the reboot command if you need it. I don’t find it necessary though.
            Awesome. I figured that the python library wasn't properly closing connections/relinquishing resources.
            Will definitely give it a try.
            Side-note - this is my second KLF - first one I had for two years and was connected via a fleet of relays to the wires - that one also required constant power cycles, and I believe that constant cycling is what killed it. Fortunately it was still under warranty.
