Awhile ago I finally took the plunge and upgraded to HS4. Other than some UI quirks things have gone quite smoothly, especially considering how many wierd/unsupported/customized things I have going on. Since then I haven't done any upgrading, and was thinking it may be about time to update my z-wave plugin.
I'm trying to understand the z-wave plugin upgrade path. I'm currently running the HS3 legacy z-wave 3.0.2.0 plugin. When I look at the plugins pages, I see the following:
Under Legacy Plugins:
Z-Wave Core, 3.0.9.0. And it has a blue check mark beside it.
Under HS4 Plugins:
Z-Wave UI, 1.0.0.0.
It LOOKS like what I want to do us install the Z-Wave Core, which may or may not be simply a re-named upgrade to the "Z-Wave" 3.0.2.0 plugin I'm currently running. Then, after doing that, I suspect I want to install Z-Wave UI.
So my questions are:
1. Are my assumptions above correct? If not, then what do i want to install/uninstall to get current?
2. Are there any potential implications I should be aware of in doing the above upgrade? ie. anything I may potentially/likely break, or functionality that will change?
Many thanks in advance,
Paul
Under HS4 Plugins:
Z-Wave UI, 1.0.0.0.
Paul
