I recently upgraded from HS3 to HS4 and have run across an issue in the logging for the Z-Wave PI. In the logs, the device name is duplicated in the message line. This is causing a problem with scripting I have written in conjunction with the Jon00 HS4 Log Monitor and the Jon00LogMessage variable. Specifically, whenever I try to issue the hs.GetDeviceRefByName command in my script, the command fails to retrieve the Reference Number because the JON00LogMessage variable picks up a string that is not a valid device name:
As you can see, the message duplicates the device name every time. "Living Room Device Light Bulb C" becomes "Living Room Device Light Bulb C Light Bulb C". This appears to happen every time a Z-Wave Error where the Failed sending Z-Wave command to device: is logged.
Can you please look into this and correct the problem? This seems to be a bug in HS4 that was not present in HS3.
