I had a lot of luck with this device over the last 6-7 years, but I recently lost my HS4 databases in a shutdown issue. So I had to rebuild from scratch. Even after following the guidance to backup/restore my zwave interface to clear routes.. i still can't get the cooper scene switch to be reliable. It kind of worked, now not working again.
Any thoughts or debugging tricks? Next step is to factory reset the scene controller itself and start over. If that doesn't work, im going to switch it over to an insteon scene controller and add an insteon hub
