What's the solution when you can't remove a node with the "remove node" command and when you try to remove bad node, it says the device is in use. I've tried a dozen times.
Remove Fibaro The Button -- trying to remove
Randy mentioned something in another post about creating a device from the bad node, then deleting that device and the node was able to be removed thereafter. (I think I got that right.) Look under z-wave plugin "Advanced Functions", then at the bottom select "Create Homeseer Devices" and finish the process. The bad node should show up under in your devices, then you can go from there. At least that's how I remember clearing up a similar issue several months ago. Good luck.
