issues with Aqara and Ikea devices + range issues
    #16
    How does the mesh learning work on this zigbee plugin? I'm having trouble talking to a lightbulb 10ft from the other line of sight with no walls. left works, the closest repeater is directly behind it on the other side of the wall. but the 2 lights to the right have no control
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
      #17
      spud just checking in, any luck with the Ikea TRÅDFRI sensor?
      my zigbee is now mostly working minus a few minor issues.
        #18
        Hello, wanted to check in and see if you had managed to make the Ikea TRÅDFRI buttons work? zigbee has been working but from time to time they stop responding,
          #19
          spud any updates on the ikea devices?
            #20
            Sorry for the non response.
            Unfortunately adding support for the ikea button requires major changes in the underlying library, so I don't have any update about this for now.
              #21
              I am also a user of this plugin (since a couple of weeks)
              But i have a couple questions
              I have added a aqara temp/hum sensor and i am missing the battery level and sometimes humudity is reported 0
              Is this a plugin problem or something i did wrong?
              I also own a aqara pir, this one is always on occupied with light/dark at 0 or 1
              i did remove the pir but can not add it again, but is this a known problem?
