Is this going to be actively supported?
    Last Christmas I was lucky enough to get some zigbee gear. its been nearly a year and its just not working well. Devices are not compatible, the commands often don't get sent. is this pluging going to be supported going forward or is there just not enough resources to work on it?
    whats not working?
    Ikea remotes not supported
    Aquara devices mostly work but sometimes just don't
    Osram sylvana bulbs only work sometimes (could be a bulb issue)
    overall the whole thing is very disappointing and unreliable.
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    https://docs.homeseer.com/display/HS...Zigbee+Devices
    HomeSeer Version: HS4 Pro Edition 4.2.18.1
    Operating System: Microsoft Windows 10 Pro - Desktop
    Z-Wave Devices via two Z-Net G3s
    Zigbee Devices via RaspBee on RPi 3b+
    WiFi Devices via Internal Router.
    Enabled Plug-Ins
    AK Weather 4.0.5.37,AmbientWeather 3.0.1.9,Big6 3.34.0.0,BLBackup 2.0.63.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 3.3.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 3.30.1003.1,JowiHue 4.0.8.7,LG ThinQ 4.0.24.0,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.4,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 3.0.11.0 2
      whats not working?
      Take a look at the JowiHue plugin with deconz and a Conbee II. Wim (plugin developer) uses Zigbee extensively and is actively adding device support and bug fixes.
        It says it all .... last update 09-2020
          i gave up and moved to mcsmqtt with zigbee2mqtt. this is working better for me now.
