I am trying to get this plugin configured across two VLANs and am at a loss.
I have Unifi equipment and am running multiple VLANs. For this project, two of them are relevant:
Today I am facing a similar issue where the Hometroller is on 250 (along with most IoT devices), and I can't seem to get it to discover the speakers on 99. In this case I cannot move the Hometroller to 99. I've consulted the FAQ ("If you are using VLANs, check the section how to set this up"), but can't find further documentation. I have also searched this forum but can't seem to find any posts on the subject.
Has anyone had success with Unifi where Homeseer and the speakers are on separate VLANs? The Listening port is receiving nothing (picture attached) so I know it's the network configuration. I have manually set the event and discovery ports per the documentation and I believe I have the firewall rules set correctly, but routing (maybe TTL) may be the problem. I read that port forwarding can solve this, but can't find further documentation on that.
Avoiding all the Unifi network config, I wish I could add a secondary interface to the Hometroller, put it on the 99 VLAN, and somehow only allow the Sonos4 plugin to communicate on it.
The speakers communicate via SonosNet with each other and connect to my network via one Ethernet connection on a Sonos Port.
Plugin Version: 4.0.1.12
HomeSeer HS4 ZEE S2 (Upg from HS3ZS2) Edition 4.2.7.0 (Linux)
Happy to provide any additional information needed
- VLAN 250 - IoT - 192.168.250.0/24
- VLAN 99 - Trusted - 192.168.99.0/24
