NEVER MIND. Had duplicate instances.
Back in HS3 days I used to use Pushover a lot. After I upgraded to HS4 for some reason it stopped working so I uninstalled it and lived without it.
Now I have just purchased the HS4 version. Setup went well and since I already had a Pushover account I used the same User and Application tokens as I used before.
When I try to create a Pushover event action I get an error when selecting the Message Type.
Unable to save changes : A view with an ID=212-6170-label-u5bbovd2w311ub99f6ppkk2apkftw8 already exists in the collection.
I'm guessing that somewhere there are a few bits left over from when I used to use it. Can you help?
MESSAGE BOARD COPY SECTION FOR FORUM POSTS
Date/time 8/12/2022 1:29:25 PM CDT
Version HS4 Standard Edition 4.2.14.0 (Linux)
MONO Version Mono JIT compiler version 5.20.1.19 (tarball Thu Apr 11 09:14:25 UTC 2019)
License Registered
Confguration File /usr/local/HomeSeer/Data/HomeSeerData.json
Uptime 6 Days 0 Hours 19 Minutes 44 Seconds
Lan IP 10.0.1.5 (hometrollerSEL)
Device Count 171
Event Count 118
Plugins Enabled PHLocation:,drhsIpPlugIn:,BLOccupied:,Z-Wave:,EasyTrigger:,Z-Wave UI:,MNS Insteon:,Pushover:
Modules/Threads 107 Modules, 63 Threads
Available Threads 199
HomeSeer Memory Used 124 Mbytes
Plugins Installed BLOccupied 2.0.28.0,drhsIpPlugIn 0.0.0.31,EasyTrigger 3.0.0.74,MNS Insteon 4.0.4.0,PHLocation 3.0.1.109,Pushover 4.0.7.0,Z-Wave 3.0.10.0,Z-Wave UI 1.0.0.0
License Registered
Device Count 171
Event Count 118
