Documentation for Shark Robot Plugin
This is a sticky topic.
    Please find the documentation for this plugin on GitHub.
    Hi. Does this work on HS3?
      No, this is an HS4-only plugin.
        have two units, one mop, the other self empty
        works fine off of I-Pad
        having error
        Click image for larger version  Name:	shark.jpg Views:	0 Size:	14.0 KB ID:	1444566
        Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
          Can you please see which robot matches that DSN? You can see a robot's DSN in the Shark Clean app in settings, select a robot, then scroll to the bottom.
            will do in about an hour, time to go home from work
              AC000W08324145 in the Shark app AC000W003364264 in your app.. my bad
              I must have screwed it up when I deleted and are-reinstalled. will delete again and re-install unless there is an easier fix
                You said you have two units, right? Does the DSN logged in HomeSeer match either of your units?
                  an older unit ( 1st gen ) now in box in garage
                  I have deleted and hope upon restart it will update to info on shark web
                  the I pad is correct with both units
ID:	1444750 looks like we got it, not at home to see if it is running around, but app in HS is operating correctly
                      Glad to hear it. I'll see if I can make the plugin ignore older units, but without owning one it's a little tricky.
                      Is there any possibility you could register your older unit on a separate Shark account and privately share the password with me?
                        can do... the older unit worked, I am sure the problem was mine
                        on a bright note,,,, Would love to see two enhancements... Notifications, and Running time
                        my units will tell me when hair is stuck in wheels, etc and with the auto dump, need a reminder to empty the canister
                        Geary
                          The device created by the plugin doesn't appear to be visible in google home (I did re-link). Is it supposed to? Any way to control the vacuum with voice?
                            Unfortunately not, I don't believe HS has the capability of exposing specialty devices (anything besides lights, locks, and thermostats) to voice assistants.
ID:	1448842 just noticed this error.. both nnits ...
                              Click image for larger version  Name:	shark.jpg Views:	0 Size:	5.6 KB ID:	1448841
