Alarm panel customisation options
    Hi Blade
    Does the HS4 version have these options? (or will they arrive at any time)
    I did upgrade to the HS4 version but I could not find these options so had to revert back to the HS3 version.
    I have a fully customised HTML panel with juggling number keys so I am keen to keep that functionality.
    Hi Bob,
    Any news on this? Is it coming soon or never?
    /Marcus
      Yes I saw it and I will get to it but I am super busy and working 12-14 hour days at work
      Perhaps this weekend I may be able to fit it in
      Cheers,
      Bob
        Superstar!
          Hi Bob
          Any progress this weekend?
            Nope I had to work all weekend
            I had 75 hours for last week so I had no time
            Cheers,
            Bob
              Wow! That sounds tough...
                Try out 4.0.15
                There is a new tab on the options page
                I did not test it so let me know
                Cheers,
                Bob
                  Thanks Bob! Really appreciated. We are close...
                  Issue 1:
                  If i put in just the html file "NewAlarmPanel.htm" instead of the path as per HS3 version then when I view the panel get this on the URL:
                  http://{host}/BLSecurity//blsecurity/NewAlarmPanel.htm
                  If I manually change the URL to:
                  http://{host}/BLSecurity/NewAlarmPanel.htm
                  So it seems to insert a redundant "/blsecurity" into the path
                  BTW: will this affect the return path in blsecurityoptions.js because we have a "customPanelUrl" property
                  Issue 2:
                  Has the HS4 system necessitated a change of the JavaScript functions? My functions no longer work. I guess I need to modify my custom panel because I only see "error" thown when triggering any alarm/sleep/perimeter modes
                  Issue 3:
                  Deselecting the CHECKBOX "Custom Alarm Panel" or blanking the "Custom Alarm Panel URL" field does not deactive that customisation. So once the customisation is set it always attempts to display the custom panel. Workaround is to disable and enable the plug in.
                  Hope this helps - and thanks again for the extra work
                  Superman!
                    Issue 1:
                    Issue 2:
                    Issue 3:
                    Superman!
                    Blade Bob-
                    Not real clear looking at the release notes, which of these have you been able to address? Running 4.0.18 on HS4.
