I've installed the plugin on a test license. The program looks to be perfect for my needs. However, I cannot get the simplest action to trigger. As a test, I'm triggering a light switch upon a motion detector going "Motion". Both devices trigger well though HS4 itself. The log does not show that the motion sensor is triggering, even though HS clearly shows the change of state of the motion sensor. Both devices are included in "Devices". Everthing works as expected except the trigger never happens. I easily could have overlooked a simple switch or something, but out of ideas where to look. Suggestions ? Thanks Steve
