It looks like the HS4 HSMyQ beta 4.0.3 is setting its Control Use values incorrectly (or at least, inconsistent with how it works in HS3).
I believe the "Close" status should have a "Control Use" of "DoorLock", and the "Open" status should be set to "DoorUnLock" -- this is consistent with how the MyQ plugin worked in HS3.
Also, the HS4 "Control Use" settings are generally confusing as there now seem to be duplicate options like "Off" and "_Off" with no apparent way for an end-user to know why there are different versions - is there a reason for this and, if so, can it be made (much much) clearer in the user interface.
Thanks.
This impacts how the homebridge plugin for HomeSeer works and it would be helpful if it could be fixed.
HS4 Garage Door "Control Use"
Compare to HS3 Garage Door Control Use settings.
Thanks.
