Can this be added to Alexa so that I can use voice commands to open or close the garage door? When I add it to Alexa it is just seeing it as a lock. Has anyone else got it integrated with Alexa? If so, how did you do it?
MyQ and Alexa
At one time I had the following setup with Google Home although not using it anymore. Think it should work with Alexa.
Virtual device with 3 V/S pairs: 0=off (control use Off), 1=on (control use On), 2=idle
Alexa routine: "Alexa, open garage door" turns the virtual device on
HS event: IF virtual device is set to On, set MyQ device to Open, then set virtual device to Idle
Alexa routine: "Alexa, close garage door" sets the virtual device to off
HS event: IF virtual device is set to Off, set MyQ device to Close, then set virtual device to Idle.
If there's a problem with Alexa recognizing the virtual device with 3 value/status pairs, then separate virtual devices could be created for Open and Close. I think this should work if Control Use is only set for 2 of the values.-Wade
I don't think you need to set the virtual device to "idle" though. Can't you just leave the virtual device to off for closed and on for open?
Also, can you create a virtual device that has "open"/"closed" in Alexa? I created the virtual device in HS and I have it open/closed but when it is seen in Alexa it shows as on/off.
Originally posted by pcgirl65 View PostI don't think you need to set the virtual device to "idle" though. Can't you just leave the virtual device to off for closed and on for open?
Originally posted by pcgirl65 View PostAlso, can you create a virtual device that has "open"/"closed" in Alexa? I created the virtual device in HS and I have it open/closed but when it is seen in Alexa it shows as on/off.-Wade
