I recently moved over to Ubuntu for HS4. I am having issues with OOM (out of memory manager) killing HS4. So, I am logging all the memory usage.
At least one culprit appears to be Ecobee plugin.
While the memory usage of the plugin seems normal, it is causing the HS4 console to consume a lot of memory.
In a span of two hours, the memory footprint of HS4 doubled in size. I shut it down, disabled Ecobee, restarted ... and the memory footprint looks looks normal.
There are a lot of moving parts on Ubuntu install ... mainly that there is the mono run-time in the middle. So, it is difficult to put a finger on it...
But, I do not see such rampant memory usage with the other plugins or with the HS console ... until I enable the Ecobee plugin.
Has anyone see this before?
