Has anyone tried to use the plugin to take control of turning your humidifier on/off? There are 2 elements I assume can be used to control this, Humidifier Level (0-100) and Humidifier Mode (OFF/Manual/Auto). When I write/change these elements from the homeseer side, they eventually get overwritten by the ecobee with the values from that side. I cannot tell if the ecobee is getting the level setting since there is no way to view the humidity setting. However I know it is getting the mode change values, but the change seems to be temporary as eventually it gets updated from the ecobee itself overwritting my change.
Anyone else try any of this? To me, the elements used to control the ecobee should not be also written to be the ecobee, but I am not sure if this is a homeseer plugin issue, or an ecobee api issue
