The documentation is included in your HS4\html\WiFiThermostat directory on your server and via the plugin's Documentation menu, or you can access it here: Honeywell WiFi Thermostat Plug-In User Guide.pdf
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
