Missing graphics for inside/outdoor temp?
That is what that means. And the missing "Honeywell WiFi Thermostat" tab is something I've just seen on my production system, even though it shows up on newly added devices, so I'm looking into that as well. I have a theory so hopefully an easy fix.
I was able to pull this from the PI trace log if it helps? Thanks
{"success":true,"deviceLive":true,"communicationLost":fal se, "latestData":{"uiData":{"DispTemperature":65.0000,"HeatS etpo int":65.0,"CoolSetpoint":78.0,"DisplayUnits":"F","StatusHea t ":2,"StatusCool":2,"HoldUntilCapable":true,"ScheduleCapa ble" :true,"VacationHold":0,"DualSetpointStatus":false,"HeatNextP eriod":38,"CoolNextPeriod":38,"HeatLowerSetptLimit":40.0000, "HeatUpperSetptLimit":90.0000,"CoolLowerSetptLimit":50.0 000, "CoolUpperSetptLimit":99.0000,"ScheduleHeatSp":70.0000," Sche duleCoolSp":78.0000,"SwitchAutoAllowed":false,"SwitchCoolAll owed":true,"SwitchOffAllowed":true,"SwitchHeatAllowed":true, "SwitchEmergencyHeatAllowed":false,"SystemSwitchPosition ":1, "Deadband":0.0000,"IndoorHumidity":21.0000,"DeviceID":73 7112 1,"Commercial":false,"DispTemperatureAvailable":true,"Indo or HumiditySensorAvailable":true,"IndoorHumiditySensorNotFault" :true,"VacationHoldUntilTime":0,"TemporaryHoldUntilTime":0," IsInVacationHoldMode":false,"VacationHoldCancelable":true,"S etpointChangeAllowed":true,"OutdoorTemperature":128,"Outdoor Humidity":128,"OutdoorHumidityAvailable":false,"OutdoorTempe ratureAvailable":false,"DispTemperatureStatus":0,"IndoorHumi dStatus":0,"OutdoorTempStatus":128,"OutdoorHumidStatus":128, "OutdoorTemperatureSensorNotFault":true,"OutdoorHumidity Sens orNotFault":true,"CurrentSetpointStatus":2,"EquipmentOutputS tatus":0},"fanData":{"fanMode":0,"fanModeAutoAllowed":true," fanModeOnAllowed":true,"fanModeCirculateAllowed":true,"fanMo deFollowScheduleAllowed":false,"fanIsRunning":false},"hasFan ":true,"canControlHumidification":false,"drData":{"CoolS etpL imit":null,"HeatSetpLimit":null,"Phase":-1,"OptOutable":false,"DeltaCoolSP":null,"DeltaHeatSP":null ," Load":null}},"alerts":"\r\n\r\n"}
Do the FALSE results mean those Outdoor Temp and Humidity values are not available from Total Comfort for my Thermostats?
Can you look at your root device and grab the json data? Most likely it's just not reporting that. I feel like they changed that at some point in the past...
Quick question...I do not have a HS4 device for the outdoor temperature or humidity although my thermostat displays do. Should it have been included back when I installed the plug-in?
Thanks, that's exactly what I needed to see! I'll look at the assignment of those VGPs and how I calculate the image name based on temperature bands and get that fixed.
- Likes 1
Code:http://192.168.1.15/WiFiThermostat/images/Thermometer-generic-12.png
There were, yes. Can you right click on the broken image in the HS web interface and copy the image address and paste it here?
I noticed in HS Buddy that I was missing graphics for the indoor and outdoor temps as reported by the plugin:
I checked the devices and there are no graphics set up for these, example:
I'm pretty sure there were range graphics there in previous versions, right?
Tags: None
