Is it necessary to upgrade to the HS4 version our can I continue using the HS3 version? Are there significant differences between them?
Upgrade from the HS3 version
Now that I have an HS4 version, I no longer allow future versions of the HS3 version to run under HS4. So you can keep running your HS4 version, but you will no longer be able to upgrade HS3 versions if I make any future changes, bug fixes, etc. There are no significant differences; once I came out with a 3.X and a 4.X, they're now based on the shared stuff where it comes to talking to Honeywell.
The issue is that when I make a change, I have to test:- Fresh install on Windows of the HS3 version
- Fresh install on Linux of the HS3 version
- Upgrade from pervious version on Windows of the HS3 version
- Upgrade from previous version on Linux of the HS3 version
- Fresh install on Windows of the HS4 version
- Fresh install on Linux of the HS4 version
- Upgrade from pervious version on Windows of the HS4 version
- Upgrade from previous version on Linux of the HS4 version
Originally posted by mkbemail@gmail.com View PostIs it necessary to upgrade to the HS4 version our can I continue using the HS3 version? Are there significant differences between them?
Originally posted by mkbemail@gmail.com View PostThank you for the quick response. What you wrote makes complete sense. There was no real reason to ask other than finding time to get it done. When upgrading do I use the same license used for the HS3 version?
I have to compliment you for this plug in. It works amazingly well.
There's a coupon process for getting the free upgrade - that part is out of my control. You can read about that here: https://forums.homeseer.com/forum/hs...54#post1577854
