Update to 4.2.1.0 failed
This topic is closed.
    Tried to upgrade from v4.2.0.10 to v4.2.1.0 this evening and it failed:
    "Installation of package Honeywell WiFi Thermostat failed. Try disabling the plugin first, then re-try the update."
    The problem is, the plugin no longer appears on my Homeseer Plugins page (under Manage). And if I try to install the plugin from the store I get the same error.
    Found this in my log:
    HomeSeer Updater: Package file not found: /usr/local/HomeSeer/Updates4/Honeywell WiFi Thermostat4.2.1.0/debug-list.html
      Same here... Good thing I snapshotted the VM first...
        Looks like the file is named debug_list.html and something is looking for debug-list.html (underscore vs. dash).
          Looks like install.txt is the culprit. I tried fixing it but don't know how to get HS to use the locally installed update instead of downloading it again from the store with the bad file.
            I had the same error, I just restarted HS and the update was installed and working
              That's a strange behavior because one HTML file was named wrong - sorry about the typo, though!
              4.2.1.1 has been submitted to correct that issue.
                Ha, thanks. I rebooted my Homeseer Pi and sure enough the new plug-in was installed and working. Should have thought to try that.
                  Closing this issue as resolved.
