Both Low and High Target Temp Controls default to 50 degrees in the dropdown. Would be better presented as the nearest current target (rounded to nearest), so as to prevent mistaken clicks (and making large adjustments) and to default you to the ballpark of where you would be setting.
Edit: the dropdown resets to 50.0 after every selection. If the dropdown can't exhibit the behavior I mentioned, maybe a slider by default could be better.
