4.0.10 - using HS default icons
    Hi Bob
    I had time to investigate this some more.
    Looking at device ref 300.
    in the config xml file.....the on/off images are defined
    . Click image for larger version  Name:	Screen Shot 2021-08-04 at 8.29.26 AM.png Views:	0 Size:	896.1 KB ID:	1487499
    The device shows different icons in HS4....(default?)
    Click image for larger version  Name:	Screen Shot 2021-08-04 at 8.27.54 AM.png Views:	0 Size:	169.5 KB ID:	1487500
    I did check the gif in question is available on the filesystem.
    Click image for larger version  Name:	Screen Shot 2021-08-04 at 8.33.01 AM.png Views:	0 Size:	396.2 KB ID:	1487502
    The detailed startup log should have details of this device as it is old and hasn't changed since HS3 days.
    dumpdevice data in case it helps.
Name:	Screen Shot 2021-08-04 at 8.30.36 AM.png
    HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
    BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
    DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
    The plugin will no longer take over the sensor properties like in HS3
    If you are using a virtual device for the sensor then all status updates will happen on it
    Cheers,
    Bob
      I'm confused?
        The plugin used to change the device string in HS3 and include the on or off image as well as text and a time string
        Is this what you are missing in the HS4 version?
        Cheers,
        Bob
          yes
            I will check into getting that back in there
            Cheers,
            Bob
              Would be great thank you, no rush
                Try out 4.0.11 BETA and see if they update
                Cheers,
                Bob
                  Good news!!! it works.
                  So my use model maybe different from others. I use computer to setup HomeSeer and HStouch for day to day family operation, with custom screens.
                  I never use grid view in HS4.....This change has extra info in grid view, which may adversely affect others.
                  Click image for larger version  Name:	Screen Shot 2021-08-04 at 12.53.07 PM.png Views:	0 Size:	82.8 KB ID:	1487576
                  the same info on my HStouch screen looks great because I can select the exact info I require.
                  Click image for larger version  Name:	IMG_1864.PNG Views:	0 Size:	200.6 KB ID:	1487575
                  Maybe something to consider.....
                    OK great
                    I will give that some thought
                    Cheers,
                    Bob
