Hi Bob
I had time to investigate this some more.
Looking at device ref 300.
in the config xml file.....the on/off images are defined
The device shows different icons in HS4....(default?)
I did check the gif in question is available on the filesystem.
The detailed startup log should have details of this device as it is old and hasn't changed since HS3 days.
dumpdevice data in case it helps.
