4.0.12 Using an awful lot of CPU.....
    #31
    This is very odd because BLRadar is only acting on the callbacks being sent by HS4
    Is rfxcomm not showing any activity on the sensors - something is causing HS to send those callbacks
    Cheers,
    Bob
      #32
      I'll switchback to HS3 BLRadar plugin and see what happens.
      HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
      BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
      DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
        #33
        The code for processing the callbacks is the same in HS3 and HS4 version of the plugin
        This is odd
        Cheers,
        Bob
          #34
          but isn't the sdk/capi different?
            #35
            Yes the value changes are coming into the plugin from HS
            Let me look
            Cheers,
            Bob
              #36
              Try out 4.0.13 BETA
              Cheers,
              Bob
                #37
                Every motion/dusk sensor is last device change updated every few seconds in .13 - Even though I have switched off the device string update with time option......
Name:	Screen Shot 2021-08-16 at 10.57.57 AM.png
Name:	Screen Shot 2021-08-16 at 10.58.14 AM.png
                  #38
                  Install 4.0.14 BETA and capture me the last change date/time updating
                  Cheers,
                  Bob
                    #39
                    4.0.14 installed....devices currently don't change unless a valid motion occurs. Will keep an eye on it.
                    All devices change regularly if the "Include Time information" in devices string is enabled.
                      #40
                      Yes that is correct
                      Is the cpu usage better?
                      Cheers,
                      Bob
                        #41
                        So far CPU is fine.....but it has taken sometime in the past for toggling to begin. Once it starts it continues.....
                        I'll get a pushover message if CPU load goes above 30%
                          #42
                          It's behaved itself since yesterday....certainly progress. Devices are toggling as expected and look at the nice time spread on them.....Not all devices changing every few seconds.
                          thanks
                            #43
                            OK good
                            I will release this build
                            Cheers,
                            Bob
                              #44
Name:	Screen Shot 2021-08-17 at 7.50.44 AM.png
