Issues with 4.0.17.0 beta
    Hi Bob,
    Just reporting back some issues I have found:
    1. Seems to be an issue with value based settings on sensors.
    They are always re-presented as empty - even if I change them in the BLRadar.xml and restart the plug in
    2. No defaults on off/on/unknown
    The HS3 version used to put some defaults into these fields but HS4 version is blank (Which makes it appear like they don't work)
    3. Movement device selection
    I have created two sensors which appear to work correctly and echo my motion sensors. However, if I try to define "Movement" then the movement dialog drop downs are always blank
    Best regards
    /Marcus
    Can you give me some screenshots of where these are happening
    Cheers,
    Bob
      As an example: This is after creating two sensors:
Name:	BLRadar - two sensors.jpg
      And when I go to "Movement" All I get when I attempt to create a new movement is this:
Name:	BLradar - movement.jpg
      There is nothing on the drop downs
      Also notice the top right corner has a ? in it. I think it is "missing" a character somehow but this may a HS4 PI framework issue
        Can you try out 4.0.18 BETA
        Cheers,
        Bob
          I can now see the sensors but when I SAVE a "movement" it gives a blank name:
            I also noted that the Movement device created does not have the default icons that the HS3 version had - was this on purpose?
            This is the HS3 version in HS4
            This is the HS4 version in HS4
              Try 4.0.19 BETA
              Cheers,
              Bob
                Hi Bob
                Yes, now the Movement label is shown
                However now seen this:
                Bug 1:
                BLRadar > Activity Log
                http://{host}/BLRadar/activity.html
                Actually shows the Activity Log of BLSecurity even though the URL is different:
                http://{host}/BLSecurity/activity.html
                The heading on the page is "Security Activity"
                Bug 2: Nothing showing on Delayed events (should there be at least a headers or something?
                The delayed events screen is blank on this url
                http://{host}/BLRadar/delayedevents.html
                Bug 3: When creating a "Movement" the drop down lists show the sensors but after it is saved, they show the wrong sensors
                creation:
                After creation
                  Also noted that when creating new Sensors it is not possible to add the "Motion Sesnsor Off Wait Time (minutes)" value as the label "Battery last changed" is overlayed on the field:
                    And I suppose you know about this character issue (I guess it should just be the character "x")
                    Best regards
                    /Marcus
                      Also found another. When creating a sensor and checking Value Triggered and entering On and Off values. After SAVING and returning to the pop up the values are all cleared.
                      Cheers again
                        Try out 4.0.20 BETA
                        Cheers,
                        Bob
                          1. Activity Log shows BLSecurity log - TO DO
                          Click image for larger version  Name:	BLRadar-DelayedEvents.jpg Views:	0 Size:	38.1 KB ID:	1499410
                          2. Delayed events report - Now see headings but shouldn't they "align top" and be in their own columns?
                          Click image for larger version  Name:	BLRadar-DelayedEvents.jpg Views:	0 Size:	38.1 KB ID:	1499408
                          3. Saved movement showing incorrect sensors - FIXED
                          4. Motion Sensor Off Wait Time (minutes) - can now see it but can't enter value in it - PARTIALLY FIXED
                          5. Invalid character to close popup - FIXED
                          6. Value Triggered options lose display when viewed - FIXED
                          7. Default entries for new Sensors On/Off/UNKNOWN | String, Image - TODO ?
                          Getting there
                            Try out 4.0.21 BETA
                            Motion Sensor Off Wait Time (minutes) is only enabled for an active zone
                            Cheers,
                            Bob
                              1. Sensor "Activity Log" showing wrong data - FIXED
                              2. Delayed Events page headings not aligned - FIXED
                              3. Motion Sensor Off Wait Time (minutes) cannot be entered on new Sensor - FIXED
                              4. Default entries for "ON" Status/Image fields="On String", "On Image" - TODO (unless default values in text fields are impossible on HS4 pop ups, or you have decided to change behaviour)
                              5. Default entries for "OFF Status/Image" fields = "OFF String", "OFF Image" - TODO (unless default values in text fields are impossible on HS4 pop ups, or you have decided to change behaviour)
                              6. Default entries for "UNKNOWN Status/Image" fields = "UNKNOWN String", "UNKNOWN Image" - TODO (unless default values in text fields are impossible on HS4 pop ups, or you have decided to change behaviour)
                              Nearly there now
                              /Marcus
