pseudocode I'm hoping to use the multi-sensor to handle turning on a virtual switch whenever motion is detected on any of the motion sensors in one of my larger rooms, and then have it turn off that same virtual switch when there is no motion across all the motion sensors. Right now, it only turns on the virtual switch, but never turns it off on no motion, could this functionality be added as another option/checkbox on the multi-sensor like you did with the multi-switch?
Even better would be if the multi-sensor could actually be set as a "motion sensor/switch" itself without having to create yet another virtual switch to link to it.
