Unistall plugin issue
    I unistalled plugin and I have many warning related to Updates plugin. What's am I doing wrong ?
    SOLVED: I fixed device/feature relationship (Setup / Labs). That's created new devices, I've deleted and no more warning.
      Good to hear. That would have been my advice too, sounds like somehow your devices.json got corrupted. Did you have issues prior to uninstalling?
      For the record, when you uninstall the (any) plugin, HS4 stops it and deletes its .exe, its .exe.config and if it exists also its .exe.json. The plugin is not involved in this process and other installed files will stay behind, as well as devices/features. If you want to clean up further, you might consider deleting the following manually:
      - In the Config folder: files UpdatesPlugin.ini and UpdatesPlugin.ini.bak
      - In the Docs folder: Updates Plugin for HomeSeer HS4 manual.pdf
      - (In html: the UpdatesPlugin folder with its content - This will actually be deleted when uninstalling)
      - In html/images: the UpdatesPlugin folder with its content
        Thanks for the advice. I didn't get issue to uninstalling, but plugin wasn't stop before uninstall.That's probably related to that.​
