Sticky: Introducing Z-Wave Parameters Plugin
This is a sticky topic.
    #16
    I'm using Vivaldi (Chromium) - the request being sent is a POST to /ZWaveParameters/Update with the following content:
    {"homeId":"EFF1938C","nodeId":7,"parameter":1,"operation":"G ET"}:
    and the response is the same as in the homeseer log:
    {"ErrorMessage":"The input does not contain any JSON tokens. Expected the input to start with a valid JSON token, when isFinalBlock is true. LineNumber: 0 | BytePositionInLine: 0.","Value":null}
    There are no error messages in the browser console.
      #17
      Originally posted by Denmow View Post
      I can not find where settings page is, I only get config and can not figure out how to link to Z-wave Database.
      Any Suggestions
      Are you sure your not using the legacy MyZWaveParameters plug-in rather than the HS4 Z-Wave Paramaters plug-in?
      Steve
        #18
        {"homeId":"EFF1938C","nodeId":7,"parameter":1,"operation" :"G ET"}:
        Plugin sees a empty string being POSTED instead of {"homeId":"EFF1938C","nodeId":7,"parameter":1,"operation" :"G ET"}. And parsing of this empty string causes the error you see.
          #19
          All my failed z-wave devices are showing up as the previous model instead of what's currently installed. For Example, replaced my dead GE switch with a Zooz switch but the parameter plugin still think's it's a GE instead of a Zooz Z-wave switch. FYI, I used the replace node feature when I did the replacement.
          Any idea how to fix this?
            #20
            You performed an incorrect procedure, you can not use the HS Replace Bad Node feature unless the two devices are the same model type. If they are different models then you have to remove the bad node and add the new device as a new addition. The issue you are facing has nothing to do with this plugin.
              #21
              Plugin reads the product information from device extra data. If that is wrong, there is no way to fix it in plugin. ( As TC1 said)
              Try using doing a rescan of device from old Z-wave device page. May be that helps.
                #22
                Great Work!! This is much better than the Z-Wave UI interface!
                It recognized my Aeotec Multisensor 6 right away and now I can update each setting individually.
                The plugin does not support bitmasked values yet, right?
                For this device (id=778 in the z-wave database) the temperature calibration (parameter #201) is bitmasked, but in the plugin appears just as a single value entry (which I manually configured to 0xF101 using the openzwave-controlpanel in Linux).
                Click image for larger version  Name:	image-1.png Views:	0 Size:	7.3 KB ID:	1523821
                This parameter in the databse is shown as (and I confirmed with the manufacturer specifications that is right):
                Click image for larger version  Name:	image-2.png Views:	0 Size:	34.3 KB ID:	1523822Click image for larger version  Name:	image-3.png Views:	0 Size:	39.6 KB ID:	1523823
                Also, adding the capability of entry values in hexadecimal would be great!
                Thanks again,
                Luis.
                  #23
                  Luis Castro The open z-wave database is not very accurate for bit-masked values. The bitmasks definitions are all over the place. You should be able to enter the hex decimal value( e.g. 0xAB) in the input box while setting the value, but after save it reverts back to whatever the Z-wave plugin returns as value as integer.
                  I could make all bitmasked as hex displayed, but then some may not understand the hex representation as it is little technical in nature for non-programmers.
                    #24
                    Originally posted by deepakkhajuria View Post
                    Luis CastroI could make all bitmasked as hex displayed, but then some may not understand the hex representation as it is little technical in nature for non-programmers.
                    I understand that. What about displaying them in both decimal and hex? Or perhaps adding an option to display them either way? That would be really useful.
                    Again, congratulations on such a nice work!
                    Sent from my Pixel 3 XL using Tapatalk
                      #25
                      Using the Z-Wave Parameters add-in...
                      I get the following error when attempting to "Save" changes:
                      "Unable to save changes : Z-Wave plugin not found A plugin with the ID Z-Wave was not found in the list of installed plugins"
                      I get same results on two separate HS4 systems.
                      I search for this error but get no hits.
                      Any ideas?
                      I have solved the problem. I updated the Z-Wave add-in from ver 3.0.2.0 to 3.0.9.0.
                      The Z-Wave Parameters add-in now works correctly.
                      Last edited by phsubscribenl; February 3, 2022, 04:58 PM. Reason: Found the root cause..
                        #26
                        phsubscribenl , What version of Z-wave plugin are you using ? It requires 3.0.9+ of the Z-Wave plugin. The function used to save parameter is not present in earlier versions.
                          #27
                          I just installed the new version and got a very nice suprise:
                          The temperature calibration for my Aeotec multisensor 6 now is shown as:
                          Thanks a lot for this addition!
                            #28
                            SSL Error 1000007d is an installation issue See here. Switching to online won't fix your issue.
                            What's the actual solution for this? Reviewing that issue, I tried cert-sync but it hasn't seemed to help. I am also on the RasPi running Linux (Raspbian Buster) and mono 6.12.0.122.
                            11:39:10 $ sudo update-ca-certificates
                            Updating certificates in /etc/ssl/certs...
                            0 added, 0 removed; done.
                            Running hooks in /etc/ca-certificates/update.d...
                            Updating Mono key store
                            Mono Certificate Store Sync - version 6.12.0.122
                            Populate Mono certificate store from a concatenated list of certificates.
                            Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed.
                            Importing into legacy system store:
                            I already trust 133, your new list has 126
                            Import process completed.
                            Importing into BTLS system store:
                            Done
                            done.
                              #29
                              Based on issues discussed here in this github issue, the Boring SSL used by Mono is not ignoring expired Root certificates.
                              Solution is to reimport everything from scratch or remove this expired certificate in mono root certificate.
                                #30
                                Thanks, here's what I did:
                                08:51:42 /usr/share/ca-certificates/mozilla:$ sudo mv DST_Root_CA_X3.crt /tmp
                                08:52:00 /usr/share/ca-certificates/mozilla:$ sudo update-ca-certificates
                                W: /usr/share/ca-certificates/mozilla/DST_Root_CA_X3.crt not found, but listed in /etc/ca-certificates.conf.
                                I already trust 133, your new list has 125
                                1 previously trusted certificates were removed.
                                Certificate removed: O=Digital Signature Trust Co., CN=DST Root CA X3
                                Done
                                done.
                                And now the online database works. Thank you!
