Relationship between parameters "Minimum Change" and "Minimum Change in %"
    I'm using the DEVICE HISTORY add-in to trend changes.
    Reducing reporting of small changes will greatly reduce the number of data points.
    Z-Wave Parameters 91 and 92 set the minimum change and change% respectively before the numbers are reported.
    Using the example below of Minimum change in Wattage=5 and Minimum change in wattage%=7
    Will these settings require a MINIMUM change of 5 and MINIMUM change of 7%... Or
    Will these settings require a MINIMUM change of 5 or a MINIMUM change of 7% to trigger the reporting?
    Thanks much for your consideration..
Name:	Z-Wave Parameters Change.png
    It is my understanding that both are valid. If the change is greater than 5 -or- if greater than 7% a report will be sent. If they are both true at once, only 1 report is sent.
      Thanks for the quick responce!
