AKWeather NOAA, Metoffice UK.. - 40 providers! PWS local Davis, Ecowitt, AW, Tempest
    #91
    Ver 4.0.2.67 (BETA) - Added SensorPush provider https://forums.homeseer.com/forum/hs...rpush-provider
Name:	sensorpush gateway.png
ID:	1552246 Click image for larger version
      #92
      Ver 4.0.2.82 (BETA) - Added preliminary Ecowitt Remote (Server) provider.
      Needs some minor work. Then I'll create separate thread for this provider.
        #93
        Ver 4.0.2.83 - Implemented Ecowitt Remote (Server) provider for Ecowitt.net
        https://forums.homeseer.com/forum/hs...-remote-server
          #94
          Ver 4.0.4.5 - Implemented New Ecowitt WittBoy (Local) provider for GW2000 and GW1100 gateways
          List of supported sensors https://forums.homeseer.com/forum/hs...icial-protocol
          Ecowitt (and clones i.e. AmbientWeather) support four different protocols:
          1. The native Local protocol which doesn't require any configuration, using port hardcoded 46000. This protocol is implemented in my plugin by Ecowitt provider. It only works if you have single PWS.
          2. The other Local protocol is configurable and implemented by AmbientWeatherLocal provider. For this one you need to set the same port number (default 7777) in both plugin Location config and WS View. The IP Address is HS server address. Don't use port 46000 here. This protocol is better if you have multiple PWS
          https://forums.homeseer.com/forum/hs...tocol-no-cloud
          3. Ecowitt Remote (Server) API - good for accessing remote stations, also provides some calculated values i.e. Dewpoint, "Feels Like" temperature, etc.
          4. New Ecowitt Wittboy All-In-One weather station with new GW2000 Gateway
          That's probably most complete protocol which works (and recommended) with GW1100 and new GW2000 gateways (not old GW1000 thought)
          https://forums.homeseer.com/forum/hs...wittboy-gw2000
          All providers can be used simultaneously - i.e. create two Locations, select Ecowitt provider for one, AmbientWeatherLocal for the other one. Then you can compare both and decide which one you like more.
          Click image for larger version  Name:	Ecowitt Wittboy1.jpg Views:	0 Size:	26.9 KB ID:	1556084​​
          ​​Click image for larger version  Name:	GW2000z.jpg Views:	0 Size:	39.5 KB ID:	1556085​​ ​
          ​ ​ Click image for larger version  Name:	2022-07-22 (1).png Views:	0 Size:	270.8 KB ID:	1558416
          Click image for larger version  Name:	2022-07-22 (3).png Views:	0 Size:	282.6 KB ID:	1558417
            #95
            Ver 4.0.4.8 - Finished New Ecowitt WittBoy (Local) provider for GW2000 and GW1100 gateways.
            Updated AmbientWeather (Local and Remote) providers to support new Ecowitt WittBoy (GW2000).
              #96
              Ver 4.0.4.12 - Added VisualCrossing provider. https://www.visualcrossing.com/weather-data
              Most comprehensive consistent weather source worldwide:
              - a lot of data,
              - Alerts
              - 11 languages,
              - 14 days forecast,
              - 14x24 hourly forecast:
                #97
                Ver 4.0.4.20 - Added newer Metoffice provider - Global Spot Data (Metoffice Spot) - with 7 daily and 48 hourly forecasts.
                It's a bit easier because it's based on the coordinates, no need to select the specific station.
                Also it's global - not only UK.
                Daily:
                Hourly:
                  #98
                  Ver 4.0.4.25 (currently in BETA) - I added MeteoAlarm provider which can be used by itself just for Alerts, also I added the service to both MetOffice UK providers ("Data Point" and Global Spot Data).
                  Note: For UK I'm also working on new Met Office NSWWS (National Severe Weather Warning Service)
                  https://forums.homeseer.com/forum/hs...-europe-and-uk
                    #99
                    Ver 4.0.4.45 - Davis WeatherLink (Local & Remote) - Added more Airlink pm_xxx devices​
                      Ver 4.0.4.47 - Added OpenMeteo provider
                      Open-Meteo is an open-source weather API with free access for non-commercial use. No API key is required.
                      - Detailed hourly forecast for 7 days (168 hours)
                      - NOAA GFS combined with hourly HRRR updates and is optimised for the U.S.
                      - GEM global and regional GEM models from the Canadian Meteorological Center CMC and is optimised for North America
                      - MeteoFrance AROME and ARPEGE weather models and is optimised for Central Europe
                      - DWD ICON API Open data weather forecasts from the German weather service DWD
                      - JMA global GSM and local MSM models and is optimised for Japan
                      - MET Norway hourly updates & 1 km forecasts for Scandinavia​
                      https://forums.homeseer.com/forum/hs...meteo-provider
                        Davis WeatherLink (Local and Remote) - multiple improvements in ver 4.0.4.53
                        https://forums.homeseer.com/forum/hs...n-ver-4-0-4-53
