AKWeather NOAA, Metoffice UK, YR.no, BOM, Openwethr, Weatherbit, W.Undergrnd, Ambient
This is a sticky topic.
    #46
    Originally posted by Pete View Post
    Wondering if you can add Meteobridge (via IP) and Cumulus (via realtime.txt file) support to your plugin
    https://forums.homeseer.com/forum/hs...84-meteobridge
    Ver 4.0.1.33 - Added Cumulus Realtime.txt
    Click image for larger version  Name:	Cumulus.png Views:	0 Size:	549.8 KB ID:	1499704
    Click image for larger version  Name:	CumulusCfg.png Views:	0 Size:	64.1 KB ID:	1499705
      #47
      Ver 4.0.1.35 (BETA)
      - Added Ecowitt and AmbientWeather Local battery devices
      - added AQICN exception handlers
      - refactored Location renaming
      - improved config screens usability
        #48
        Ver 4.0.1.42 - Added IQAir provider https://www.iqair.com/
        Note: the "info" is a link to the website page for this location
Name:	Screenshot 2021-10-14 011819.png
          #49
          Ver 4.0.1.43 - Added weatherUSA including Alerts
          Ver 4.0.1.44 - Added WeatherUSA forecasts
            #50
            Ver 4.0.1.45 - Added WeatherUnlocked (UK) provider
              #51
              Ver 4.0.1.51 - Work on PurpeAir Local
Name:	Screenshot 2021-10-24 033229.png
                #52
                Ver 4.0.1.56 - Fix NOAA2 units decoding
                  #53
                  WeatherBit stopped updating the timestamps in late October. The data does not change. I disabled and re-enabled the plug-in. I even uninstalled it and manually deleted all of the created devices and then set it up again, only to get the same result. Please help me resolve this. Thank you.
                  Lat: 35.05
                  Lon: -85.08
                  Date/time=10/26/2021 1:51:42 AM Eastern Daylight Time
                  Version=HS4 Pro Edition 4.2.5.0 (Windows)
                  License=Registered
                  Confguration File=C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.json
                  In Virtual Machine=No MFG: gigabyte technology co., ltd.
                  Antivirus=Windows Defender
                  OS=Microsoft Windows 10 Pro - Work Station
                  OS Version=10.0.19043
                  Uptime=0 Days 0 Hours 18 Minutes 59 Seconds
                  Lan IP=xxx.xxx.xxx.xxx (homeseer)
                  Device Count=627
                  Event Count=205
                  Processor:=AMD64 Family 16 Model 5 Stepping 3 at 2.70 GHz
                  Modules/Threads=137 Modules, 66 Threads
                  Available Threads=1023
                  System Load=160 Processes, 14% Load
                  Free/Total Memory=4.54 GBytes / 7.50 GBytes (60% free)
                  Free/Total Virtual Memory=5.64 GBytes / 8.69 GBytes (65% free)
                  HomeSeer Memory Used=127 Mbytes
                  Plugin Memory Used=7 EXE Plug-Ins using 268 Mbytes
                  Plugins Installed=AK Weather 4.0.1.46,BLShutdown 1.0.5.0,EnvisaLink 3.0.0.42,Harmony Hub 4.0.13.0,HS MyQ 4.0.7.0,HSBuddy 3.25.614.1,Z-Wave 3.0.2.0
                    #54
                    Lat: 35.05
                    Lon: -85.08
                    Please start new thread if you have a problem.
                    https://forums.homeseer.com/forum/hs...n-late-october
                      #55
                      Ver 4.0.1.58 (BETA) - Added Buienradar (Nederland) - Current conditions at the moment. Will add Forecast soon.
                        #56
                        Ver 4.0.1.59 (BETA) - Added Buienradar forecast
Name:	Buienradar Forecast1.png
                          #57
                          Ver 4.0.1.63 (BETA) - Weatherflow Remote API including forecast (up to 10 days)
                          For remote API you need to obtain an API key from https://tempestwx.com/settings/tokens
                          I'm not sure exactly how to obtain the key, I will investigate further.
                          And I'm also implementing Local API as well.
Name:	WeatherFlow Remote Current.png
Name:	WeatherFlow Forecast.png
                            #58
                            Ver 4.0.1.67 (BETA) - Davis WeatherLink (and AirLink) Local implemented.
                            Most values are shown. I need to add some extra, i.e. soil moisture, leaf wetness, extra temperatures, etc.
                              #59
                              Ver 4.0.1.69 (BETA) - Davis WeatherLink (and AirLink) Local done.
                                #60
                                Ver 4.0.1.75 - WeatherFlow Tempest Local (WiFi) Release
                                https://forums.homeseer.com/forum/hs...and-remote-api
Name:	Tempest Local.png
