AKWeather features requests
This is a sticky topic.
    #61
    Originally posted by Bigstevep View Post
    You have pm
    It works again
      #62
      OK, I looked for this and didn't see the request from others, so I'll jump in. I would like to see tide times displayed, here at the coast, having the ability to digest a day's tides at a glance is very helpful and I haven't had that luxury since WeatherXML went Tango Uniform. Would this be doable?
      Last edited by ewkearns; April 28, 2021, 07:56 AM. Reason: Poor spelling and grammar.
      HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
      Operating System: Microsoft Windows 11 Pro - Desktop
      Z-Wave Devices via two Z-Net G3s
      Zigbee Devices via RaspBee on RPi 3b+
      WiFi Devices via Internal Router.
      Enabled Plug-Ins
      AK SmartDevice 4.0.5.1,AK Weather 4.0.5.174,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.50.128.5,JowiHue 4.1.3.0,LG ThinQ 4.0.25.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.0.3
        #63
        Sure, if you provide more info where can I get the info?
          #64
          Originally posted by alexbk66 View Post
          BTW, whats "Event Rain"?
          The only thing I can determine from Event is that it is the amount of rain that has occurred from 12:00:01 AM until the present time. For example my display reads 1.01 in. That would be the total from midnight (it resets at that time each day) until now.
            #65
            I'll try, some of these give more information for fishermen, some just generally about tides... I separated the last two....
            https://tidesandcurrents.noaa.gov/
            https://tidesandcurrents.noaa.gov/tide_predictions.html
            https://tidesandcurrents.noaa.gov/no...tml?id=8659665
            https://www.tides.net/
            https://www.almanac.com/astronomy/tides
            https://www.tideschart.com/United-St...nswick-County/
            https://tides4fishing.com/us/north-c...et-bowen-point
            https://marineweather.net/tide/shall...point-nc-tides
            https://magicseaweed.com/
            https://www.surf-forecast.com/
            Now, the last two are primarily surfing. Not my thing, but might be attractive to others.
            Let me know if I can provide further input.
            PS
            I believe it was wunderground.com that WeatherXML used to pull tide information from. It appears they no longer have that.
            Enabled Plug-Ins
              #66
              But there's also Precipitation Day?
                #67
                Ver 4.0.0.19 - Added aqicn (Air Quality Open Data Platform) - will create a new group of HS devices for each location once correct APU key (token) is configured.
                For first cut I just added main reading, tomorrow will add more.
                https://aqicn.org/city/australia/melbourne/brighton/
                I need to research what is important out of large amount of data provided by aquicn. Including air quality forecast for 3 - 5 days.
                Anybody can provide any input?
                Configuration is simple - just register at https://aqicn.org/data-platform/token/ and enter the token in the plugin settings:
Name:	Screenshot 2021-04-29 014758.jpg
ID:	1471424 Click image for larger version
Name:	Screenshot 2021-04-29 014937.jpg
                  #68
                  Yes, but that one appears to be for the whole 24 hrs from midnight to midnight. It is almost like you have to catch it at 11:59 PM in order to see a reading because at 12:00:00 AM it gets reset to 0. The console does let you scroll through rain values such as in/day, in/week/, in/month, in/total and then there is the in/hr rate.
                  Also, pressure seems to be reading abs. Can we get a way to select rel too?
                    #69
                    I added devices for all of them, but again, they will be created only if (when) data is available.
                      #70
                      alexbk66 OOPS! I just got a remote server error 429 in CTRL. Too many requests it says. Go To Jail, Do Not Pass Go?
                        #71
                        Probably because I'm testing using your key. But since I'm going to sleep - it should clear. I think they have limit 3 calls per sec or so.
                          #72
                          Ok, no problem. Thanks
                            #73
                            BTW, you can rename the location to something shorter, i.e. Home
                              #74
                              I have multiple errors trying the .19 plugin, actually it started with version .15.
                              First of all I can get the plugin to stay running to get to settings. I uninstalled the plugin, removed every instance of it in the HS4 parent directory, restarted HS4 and still have the following errors:
                              Where it's getting my API Key (MYKEY, I erased the actual key above) I have no idea as I've never gotten into the settings to supply that key.
                              Anyway the plugin keeps shutting down and restarting and I can do anything. I'm also getting this error but I suspect it's because the plugin is shutting down when I'm trying to do something in settings:
                              Error finding plugin in GenPage: Disconnected before response received.
                              Ideas?
                              https://forums.homeseer.com/forum/hs...-trying-the-19
                                #75
                                i was wondering if you know of away to have an alert feature for severe weather like tornado, hurricane, freeze warning etc that could be used to trigger events? i use emails to trigger them now but that has not been accurate and it would be useful to change colors of RGB lighting i have to indicate warnings and when they are over
