Any Progress on Description
This topic is closed.
    alexbk66 Is there any progress on finding why Description shows up in the list of child devices? I have the PI on Ambient and it is still in the list of child devices. I am on 4.0.0.15 and dis/en Pi does nothing. No errors in the log.
    [EDIT]
    The only provider which doesn't use description is AW, because it shows just data from PWS. But for the description for AW - I might just make-up some text.
    [EDIT]
    I checked my, it doesn't have description. It must have been left when you tried another provider?
      BTW, can you please describe your AW setup? Just because I'm looking myself for PWS.
      You mentioned WS-2902A, but I mean the rest of the system, i.e. ObserverIP, etc?
          I have the older model WS-2902A, there is the exact thing available but it is a WS-2902C. On the display they both have the wind direction, wind speed, uv, solar radiation, inside/outside temp, inside/outside humidity, rain in/hr (can be set to others, day, week, month), barometric (abs or rel), moon (what phase), date, time. It has a neat part on the display that seems to know what weather is coming. Mine showed clouds with rain earlier this afternoon and it is raining now. No observerIP.
          Anything else I can tell you just let me know. Also, the WS-2902C has all the above plus dew point, heat index, wind chill on the display. The newer display is arranged a little differently than mine. It even has an optional bird spike that can be put on.
          If you want lightning detection that is optional on the WS-2000 and WS-5000 or on Ecowitt!!
          Hope this helps.
          Here is WS-2902A. I took out Description.
            From my limited understanding, 'heat index' and 'wind chill' are used for 'feels like' temperature (which all other providers show), but AW has these two instead of 'feels like'. They both are available in the API, I just don't use them because other providers don't have them. Instead I calculate the 'feels like' temperature, so please let me know if it's wrong.
            I added all of them in latest version (not published yet) - the screenshot I posted
            That's the part I couldn't find from AW - the forecast. I found how to get forecast from WU, but the AW is the only provider without forecast
              I saw this listed as one of the things the display does but I wonder if the forecast thing is done in the console itself.
              • Weather forecast: Sunny, Partly sunny, Cloudy, Rainy, Stormy and Snowy
              After looking at the API I didn't see any entry for forecast either. 🤷‍♀️
                I sent email to AW, but don't expect too much...
