World Air Quality Index
This is a sticky topic.
    I added World Air Quality Index
    Note: for configuration see this post https://forums.homeseer.com/forum/hs...39#post1470239
    Click image for larger version  Name:	Settings.png Views:	5 Size:	82.8 KB ID:	1502066 Click image for larger version  Name:	Screenshot AQI website.jpg Views:	46 Size:	63.0 KB ID:	1472325
    Hello Alex,
    You asked me what other devices you should consider adding and the Purple Air might be worth a lot if their is an audience.
    I do not own this, it has a big usage in the USA especially after the California fires
    https://api.purpleair.com
    My primary AQI device is the A3 UradMonitor but has.a very small usage even on here...
    https://www.uradmonitor.com
    https://www.uradmonitor.com/wordpress/w ... sponse.pdf
    https://www.uradmonitor.com/server-upgrade-site-4/
    Data is also available through a local API (JSON) [iP_Address/j
    Tim
      Thank you Tim, I'll have a look.
      But FYI, World Air Quality Index is international project, it's not really working with specific device network - instead it's providing data from local authorities (shown in Attribution device)
        Alex, I knew the above but I also know that there is no stations, in what I consider close to me and at times I have seen big discrepancies between my data and the three closet EPA stations that are also used by the WAQI.
        Australia, including in EPA In Melbourne actually has very limited AQ stations and that is why for the last nearly 6 years I have ran my own.
        After the California bush fires a number of years ago, it was for the same reason that the purple air got so much attention.
        I use an app named Local Haze, and the data sources, including mine, are from other than official EPA stations.
          https://forums.homeseer.com/forum/hs...ir-aqi-sensors
