Ver 4.0.0.31 - Implemented NOAA (2) Alerts
NOAA (weather.gov)
This is a sticky topic.
I found a little issue - when alert is gone - I need to clear the devices, but because I create the alert devices dynamically - it's not trivial because I don't know how many devices to clear.
I can post the new version now without clearing, or tomorrow with this fixed. It's almost 2 AM here in AU.
I realise that you can't create TTS or other triggers until you actually have an alert for your area. But I'm not sure how to go about it.
There's too many possible devices (because I support many providers) - I don't want to create all devices it this particular provider doesn't support some particular data.
Probably I need to force creating the Alert device for supported providers.
For test though you can try some location which does have current alerts i.e. 40.52, -83.24
alexbk66 I got the following error multiple times. There was an alert at 12:22pm today according to the Alert URL. The error started at 12:28pm.
Code:[COLOR=#FF0000]5/22/2021 12:28:37 PM [/COLOR] [COLOR=#FF0000]AK Weather [/COLOR] [COLOR=#FF0000]Error [/COLOR] [COLOR=#FF0000]System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: devRef at: HomeSeer.PluginSdk.Devices.FeatureFactory.CreateFeature(Stri ng pluginId, Int32 devRef) at: PluginLib.DeviceBase.CreateDevice(String name, String addr) at: PluginLib.DeviceBase.Create(String addr, String full_type, Int32 Device_Type, Int32 Device_SubType, String Device_SubType_Description, String dev_name) [/COLOR] [COLOR=#FF0000]5/22/2021 12:28:37 PM [/COLOR] [COLOR=#FF0000]AK Weather [/COLOR] [COLOR=#FF0000]Error [/COLOR] [COLOR=#FF0000][0] : CreateDevice: Specified argument was out of the range of valid values. Parameter name: devRef [/COLOR]
Originally posted by ocyberbum View Posti just wanted to say thanks Alex for the alert tab,in Noaa i have an event for extreme and severe, so im hoping this will also detect tornado, Having something like this is great!
Did it create additional root alert devices with more details?
