Ver 4.0.0.40 Added initial support for Netatmo PWS. Ver 4.0.2.19 I refactored Netatmo provider. See Configuration below for different system options. |
Configuration | ||
You have two options to support your Netatmo configuration: | ||
Option 1: Default configuration (single Location) | ||
By default all sensors are enabled and displayed under single Location (root). All additional temperatures are displayed under "Temperature Extra". I try to fit the data into standard plugin architecture - i.e. single temperature Min and Max device per Location. So for Min temperature I take minimum reading (for Max - maximum). For CO2 I display maximum of all CO2 readings. | ||
Option 2: Separate Location for additional aux module (i.e. NAModule4) | ||
If you have multiple indoor/outdoor units and want to see each reading (i.e. CO2) separately - you can create multiple "Locations" - and for each location select which sensors you want to display. I.e. create another Location for the second aux module (NAModule4), then disable this NAModule4 for the main root device, and enable only this NAModule4 for the additional root. | ||
