Canadian Weather - Environment Canada
This is a sticky topic.
    #16
    Ver 4.0.0.54 - please read Note below.
    1. Added 5 days forecast.
    2. Added Alerts (i.e. currently "HEAT WARNING").
    3. Use original CanWeather icons and weather codes.
    Forecast uses different API - instead of the station ID (i.e. CYDN) it uses forecast site id, which may be different location from the observations station. The "Info" device will also show the site ID for troubleshooting, i.e. "Site s0000508 Manitoba".
    Note: Since correct site should be selected, and also because now I use original icons and weather codes from CanWeather - I strongly recommend to delete and re-create current location.
    Please test and verify. Especially timestamps for current weather, forecast and Sunset/Sunrise - as it's difficult to guess if local or UTC time is used.
      #17
      Please also note, the forecast has short and long strings, to select which one is used I added "Use abbreviated forecast string" setting (default Off)
      Also, I added language selection setting (En/Fr)
        #18
        Thanks Alex. I will delete location then update and test.
        I will be in Air Conditioned comfort cause its a crazy early HEAT WAVE here in the great white north eh.
          #19
          Deleted my Location.
          Updated plugin
          Added Provider Saved
          It only created the current condition devices - no alerts or forecast
          I went back in and adjusted forecast from 2 days to 3 and enabled log and saved
          still no forecast and no warnings regarding device creation in the logs
          Last edited by mbdirtfarmer; June 5, 2021, 01:13 PM. Reason: -edited to delete attachments
            #20
            Click image for larger version  Name:	2021-06-05 13_00_35-Devices.png Views:	0 Size:	394.6 KB ID:	1478038
              #21
              hmm, I'll check. It doesn't seen to find forecast station...
                #22
                Ver 4.0.0.55 - install updated stations mapping file
                Should show the correct forecast site id. Note that the second distance (5 km) is from the observations station, not the current location. In some remote areas it can be quite big.
Name:	Screenshot 2021-06-06 102536.jpg
                  #23
                  Updated to 4.0.0.55
                  Initially after update, no Forecast Devices when station was CWZT-AUTO. I changed the Can_Weather station to CYDN-AUTO and Alerts and Forecast all populated.
                  Looks real good! Good work. I bet that was a bit of a challenge.
                    #24
                    BTW, tested going back to CWZT-AUTO and forecast station ID stayed same and timestamp updated on forecast devices. All seems fine.
                      #25
                      Yeah, both CWZT and CYDN use forecast site s0000508, and similar distance from your location 5564 and 5659 m.
                      Click image for larger version  Name:	Screenshot 2021-06-06 130255.jpg Views:	0 Size:	33.4 KB ID:	1478170
                        #26
                        I just installed this plugin to test out. Looks great, two small quirks though:
                        I don't seem to be able to get the drop down list of locations that you guys are showing. Mine just says "Station list is empty" then underneath it I have a Can_Weather Station field where I can manually enter in a station. For example if I enter CPOY-AUTO, it does pull up Cypress River for me, but your previous screenshots are showing a drop down list, which I seem to be missing.
                        It seems hit or miss with the ° symbol. For instance:
                        12°C - 23 ??C, Sunny. Becoming a mix of sun and cloud this afternoon. High 23. UV index 6 or high.
                        23$%0$ Mostly Cloudy (33 m ago)
                        Both of those are taken from a device created by the plugin. Sometimes it properly shows the ° symbol, but more often then not it does not.
                        Is it possible to add multiple locations to grab weather from? When I select the "Add new location" slider, then hit save, it just overwrote my first location. Is that intended or should it be creating a second location for me?
                          #27
                          It's three separate issues in your question, so I created three separate topics for them, otherwise it will be total mess discussing them in single thread:
                          https://forums.homeseer.com/forum/hs...t-of-locations
                          https://forums.homeseer.com/forum/hs...-%C2%B0-symbol
                          https://forums.homeseer.com/forum/hs...b-weather-from
                            #28
                            Frequently Precipitation or other values come back as Unknown from EnvCan. It appears to be a response to NIL, 0 or negative values. In any case is it possible to replace the string Unknown with NA (as in not available)? The image can stay the same as ? as the value is unknown.
                            The following is common in the log and possibly be related to the unknown value condition?
                            9-28-2021 16:35:15 AK Weather Warning [1106] Ajax-EnvCan: findd(pcpn_amt_pst24hrs) 'MSNG': Input string was not in a correct format.
                            9-28-2021 16:35:15 AK Weather Warning [1106] Ajax-EnvCan: findd(max_wnd_gst_spd_10m_pst10mts) 'MSNG': Input string was not in a correct format.
Name:	Capture - Copy.PNG
                            Source:
                            https://weather.gc.ca/city/pages/on-117_metric_e.html
                            Version=HS4 Standard Edition 4.2.0.0 (Windows)
                            Plugins Installed=AK Weather 4.0.1.31,HS MyQ 4.0.7.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0
                              #29
                              You can change the text yourself if you click on the device, select Status/Graphics, then click Edit for "Unknown" row
                                #30
                                Ok, I will do that. These changes survive future updates to the PI?
