Ecowitt PWS - Local Official protocol
This is a sticky topic.
    Ver 4.0.0.62 (BETA) - added Ecowitt - local WiFi API.
    When Ecowitt provider is selected - it should
    discover GW1000 series gateway automatically,
    assuming HS and the gateway are on the same WiFi.
    Click image for larger version  Name:	GW1002-1.png Views:	0 Size:	467.1 KB ID:	1480561
    Note:
    GW1000 supports two different protocols:
    1. The native protocol which doesn't require any configuration, using port hardcoded 46000. This protocol is implemented in my plugin by Ecowitt provider. It only works if you have single PWS.
    2. The other protocol is configurable and implemented by AmbientWeatherLocal provider. For this one you need to set the same port number (default 7777) in both plugin Location config and WS View. The IP Address is HS server address. Don't use port 46000 here. This protocol is better if you have multiple PWS
    If you want, you can for testing use both simultaneously - i.e. create two Locations, select Ecowitt provider for one, AmbientWeatherLocal for the other one. Then you can compare both and decide which one you like more.
    Supported sensors:
    Internal Temp/Hum GW1000 Click image for larger version  Name:	318hAAQJoPL._AC_SY350_.jpg Views:	1 Size:	18.4 KB ID:	1480603
    Wind, UV, Lux WS68 Click image for larger version  Name:	wireless-anemometer-wind-uv-light%20ws68%20(2).jpg Views:	1 Size:	21.5 KB ID:	1480602
    External Temp/Hum WH32 Click image for larger version  Name:	outdoor-temperature-humidity-sensor-32%20(4).png Views:	1 Size:	61.1 KB ID:	1480604
    Precip WH40 Click image for larger version  Name:	418wkh7hhOS._AC_SY350_.jpg Views:	1 Size:	25.2 KB ID:	1480605
    PM2.5 (AQI)
    Up to 4 sensors
    WH41 Click image for larger version  Name:	51bAUFJs+kL._AC_UL600_SR600,600_.jpg Views:	1 Size:	49.7 KB ID:	1480607
    Lightning Detector WH57 Click image for larger version  Name:	51Qr9Aw4cpL._AC_SY1000_.jpg Views:	1 Size:	60.7 KB ID:	1480608
    Multi-channel Temp/Hum
    Up to 8 sensors
    WH31 Click image for larger version  Name:	multi-channel-temperature-humidity-sensor-WH31-1%20(3).png Views:	1 Size:	259.5 KB ID:	1480609
    Soil Sensor
    Up to 16 sensors
    WH51 Click image for larger version  Name:	51ev7cDZ2-L._AC_SY350_.jpg Views:	1 Size:	47.4 KB ID:	1480610
    Leak Detector
    Up to 4 sensors
    WH55 Click image for larger version  Name:	kKOgMwdbou5_YoGFyk_uxywUZxVwR0kz3qUW3YA1NnTgA9oHrh0ny45XwMmnSd_jSuXRFFq3hLKlJPKgBor8CXC7Q6F4QGBQ3PgvwGsHoQ.jpg Views:	1 Size:	8.7 KB ID:	1480611
    Click image for larger version  Name:	Ecowitt4.png Views:	6 Size:	141.0 KB ID:	1480913
    The Ambient Weather WS-2000 and WS-5000 console have the ability to send to local just like the Ecowitt GW-1000 device. Just slight differences in the format between the two. In the latest Ambient Weather AWNET (4.2.9) tool the configuration is identical to that of the Ecowitt WS View app
      I'll check with Fine Offset Electronics, they are the manufacturer
        alexbk66 Where is the plugin getting the info for precip, uv, wind devices? The ecowitt gateway only has temp, humidity and pressure by itself.
          Wind, UV, Lux WS68
          Precip WH40
          PM2.5 (AQI) WH41
          I also have Lightning Detector (WH57), Multi-channel Temp/Hum (WH31), Soil Sensor (WH51), Leak Detector (WH55) - still need to implement.
            alexbk66 Are you going to show each child device under it's respective parent device, ie WS68 (under that would be the wind, uv and lux child devices) or are all the child devices going to be listed separately?
              No, I don't want to create many root devices, with all this separate sensors - it's still a single weather station.
                Here's the reply I have from FOSHK:
                WS2000 and WS5000 doesn’t share the same protocol as GW1000, so you are not able to fetch the data via TCP connection. The main reason is that GW1000 wifi OSC chip handles data reception and wifi bridge feature by the same processor. However with WS2000 and WS5000, the data handling was done on the display controller side, and it just pass the data to wifi for sending to the weather server.
                So their structure is not the same. We will have more devices with GW1000 feature coming: WN1900 – a station with display, WH2680, GW1100 new gateway are supporting this feature.
                I also asked AmbientWeather, but they just pointed me to their Cloud API documentation
                  Technically they are correct in the awnet app it's listed as Ambient Weather Protocol and the Ecowitt is listed as Ecowitt Protocol. But in reality they are almost identical with only the difference being the names of some of the devices and the order of the header information. I have been using this method of pulling data for more than a year to gather data from my WS-2000.
                    But as I understand, for Ecowitt I'm communicating with GW1000 gateway, not any display (as a matter of fact - I don't have any).
                    But for Ambient Weather you are pulling data from the display? What protocol exactly are you using? And add it to my plugin as well.
                      For Ecowitt I am talking to the GW1000 which does not have a screen but is their communication hub. And with Ambient Weather the Screen is the communication hub and that is what is sending the data both to the Ambient Weather Hub and to my Custom App via a telnet connection. When I get a chance I will send you data sample from both devices so you can see the differences. (Currently middle of the night here monitoring an upgrade of systems at work)
                        I know how to communicate with GW1000, I have protocol documentation from FOSHK (the manufacturer). But if you can point me to the AmbientWeather local protocol, I can also implement it.
                          To my knowledge AmbientWeather has not provided a documented protocol to their local data access. In fact it is just with the most recent awnet app update that you could even configure the console to send local. But you could cheat and use the Ecowitt WS View app to enable the AmbientWeather console to send local for some time, that is how I discovered it was possible. Like I said I can send you a copy of the data stream but I have no Official protocol documentation.
                            Alex, if your interest Ecowitt they do have a desktop client named Easy Weather 2
                            http://download.ecowitt.net/down/sof...n=EasyWeather2
                            The link below is to the Weather Exchange forum, and post 27 contains a an Ecowitt Protocol Simulator
                            https://www.wxforum.net/index.php?to...5964#msg415964
                            This is the parent thread for Fine Offset clones and note there is a whole thread identifying that not all AmbientWeather are made by Fine Offset
                            https://www.wxforum.net/index.php?board=111.0
                              Thanks guys for your info. As I said, I do have official Ecowitt documentation and full set of Ecowitt sensors from Fine Offset, the only problem is that this documentation looks like google translate from Chinese, but I mostly worked it out and already added local Ecowitt support to my AKWeather plugin (almost finished).
                              And for AmbientWeather I did get reply that they only have Cloud API, which I also added to my plugin.
                              And regarding "unofficial" APIs - I don't really like bothering with unofficial stuff which can break any time. I prefer convincing the manufacturer, doesn't always work though
