Ecowitt PWS - Local Official protocol
This is a sticky topic.
    For the battery readings it's a separate command which I need to implement, may require a bit of work (tomorrow)
    You can also try another protocol (i.e. create another location and select "Ambient Weather Local"
    https://forums.homeseer.com/forum/hs...tocol-no-cloud
      Ver 4.0.1.35 (BETA)
      - Added Ecowitt and AmbientWeather Local battery devices
      - added AQICN exception handlers
      - refactored Location renaming
      - improved config screens usability
        Thanks for the release and the presentation of the battery information. The temp sensors look good but the ewh40 is reporting 0. I replaced the battery with a new one but still same status.
        Here is some info for you. Let me know if you need anything else to export or test if you do not have this device.
        Thanks again!
        Click image for larger version  Name:	Capture1 - Copy.PNG Views:	0 Size:	24.9 KB ID:	1500949
        Click image for larger version  Name:	Capture2 - Copy.PNG Views:	0 Size:	77.4 KB ID:	1500950
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: (b) eWH31_SENSORCH1: 100 '%'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: (a) eWH31_SENSORCH1: 0 '', id: 216, signal: 4
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: (b) eWH26_SENSOR: 100 '%'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: (b) eWH40_SENSOR: 0 '%'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: (a) eWH26_SENSOR: 0 '', id: 98, signal: 4
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: (a) eWH40_SENSOR: 16 '', id: 72059, signal: 4
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: Received CMD_READ_SENSOR_ID_NEW number: 3
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: Received CMD_GW1000_LIVEDATA number: 14
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [040 : 2] 0x0D 'RAINEVENT' = 0 'Rain Event (mm)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [030 : 4] 0x12 'RAINMONTH' = 0 'Rain Month (mm)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [035 : 4] 0x13 'RAINYEAR' = 0 'Rain Year (mm)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [027 : 2] 0x11 'RAINWEEK' = 0 'Rain Week (mm)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [024 : 2] 0x10 'RAINDAY' = 0 'Rain Day (mm)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [021 : 2] 0x0E 'RAINRATE' = 0 'Rain Rate (mm/h)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [019 : 1] 0x22 'HUMI1' = 66 'Humidity 1, 0-100%'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [014 : 1] 0x07 'OUTHUMI' = 77 'Outdoor Humidity (%)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [016 : 2] 0x1A 'TEMP1' = 21.2 'Temperature 1(℃)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [011 : 2] 0x02 'OUTTEMP' = 20.6 'Outdoor Temperature (℃)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [008 : 2] 0x09 'RELBARO' = 1014.9 'Relative Barometric (hpa)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [005 : 2] 0x08 'ABSBARO' = 1014.9 'Absolute Barometric (hpa)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [003 : 1] 0x06 'INHUMI' = 57 'Indoor Humidity (%)'
        10-06-2021 16:04:39 AK Weather Info [1388] Ecowitt Local: [000 : 2] 0x01 'INTEMP' = 22.1 'Indoor Temperature (℃)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: (b) eWH31_SENSORCH1: 100 '%'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: (a) eWH31_SENSORCH1: 0 '', id: 216, signal: 4
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: (b) eWH26_SENSOR: 100 '%'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: (a) eWH26_SENSOR: 0 '', id: 98, signal: 4
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: (b) eWH40_SENSOR: 0 '%'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: (a) eWH40_SENSOR: 16 '', id: 72059, signal: 4
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: Received CMD_READ_SENSOR_ID_NEW number: 3
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: Received CMD_GW1000_LIVEDATA number: 14
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [040 : 2] 0x0D 'RAINEVENT' = 0 'Rain Event (mm)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [035 : 4] 0x13 'RAINYEAR' = 0 'Rain Year (mm)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [030 : 4] 0x12 'RAINMONTH' = 0 'Rain Month (mm)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [024 : 2] 0x10 'RAINDAY' = 0 'Rain Day (mm)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [027 : 2] 0x11 'RAINWEEK' = 0 'Rain Week (mm)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [021 : 2] 0x0E 'RAINRATE' = 0 'Rain Rate (mm/h)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [019 : 1] 0x22 'HUMI1' = 66 'Humidity 1, 0-100%'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [016 : 2] 0x1A 'TEMP1' = 21.1 'Temperature 1(℃)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [014 : 1] 0x07 'OUTHUMI' = 77 'Outdoor Humidity (%)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [008 : 2] 0x09 'RELBARO' = 1014.9 'Relative Barometric (hpa)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [011 : 2] 0x02 'OUTTEMP' = 20.6 'Outdoor Temperature (℃)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [005 : 2] 0x08 'ABSBARO' = 1014.9 'Absolute Barometric (hpa)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [003 : 1] 0x06 'INHUMI' = 57 'Indoor Humidity (%)'
        10-06-2021 16:04:24 AK Weather Info [1388] Ecowitt Local: [000 : 2] 0x01 'INTEMP' = 22.1 'Indoor Temperature (℃)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: (b) eWH31_SENSORCH1: 100 '%'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: (a) eWH31_SENSORCH1: 0 '', id: 216, signal: 4
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: (b) eWH26_SENSOR: 100 '%'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: (a) eWH26_SENSOR: 0 '', id: 98, signal: 4
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: (b) eWH40_SENSOR: 0 '%'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: (a) eWH40_SENSOR: 16 '', id: 72059, signal: 4
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: Received CMD_READ_SENSOR_ID_NEW number: 3
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [040 : 2] 0x0D 'RAINEVENT' = 0 'Rain Event (mm)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: Received CMD_GW1000_LIVEDATA number: 14
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [035 : 4] 0x13 'RAINYEAR' = 0 'Rain Year (mm)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [027 : 2] 0x11 'RAINWEEK' = 0 'Rain Week (mm)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [030 : 4] 0x12 'RAINMONTH' = 0 'Rain Month (mm)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [024 : 2] 0x10 'RAINDAY' = 0 'Rain Day (mm)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [019 : 1] 0x22 'HUMI1' = 66 'Humidity 1, 0-100%'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [021 : 2] 0x0E 'RAINRATE' = 0 'Rain Rate (mm/h)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [016 : 2] 0x1A 'TEMP1' = 21.1 'Temperature 1(℃)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [014 : 1] 0x07 'OUTHUMI' = 77 'Outdoor Humidity (%)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [011 : 2] 0x02 'OUTTEMP' = 20.6 'Outdoor Temperature (℃)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [008 : 2] 0x09 'RELBARO' = 1014.9 'Relative Barometric (hpa)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [005 : 2] 0x08 'ABSBARO' = 1014.9 'Absolute Barometric (hpa)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [003 : 1] 0x06 'INHUMI' = 57 'Indoor Humidity (%)'
        10-06-2021 16:04:08 AK Weather Info [1388] Ecowitt Local: [000 : 2] 0x01 'INTEMP' = 22.1 'Indoor Temperature (℃)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: (b) eWH31_SENSORCH1: 100 '%'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: (a) eWH31_SENSORCH1: 0 '', id: 216, signal: 4
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: (b) eWH26_SENSOR: 100 '%'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: (b) eWH40_SENSOR: 0 '%'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: (a) eWH26_SENSOR: 0 '', id: 98, signal: 4
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: (a) eWH40_SENSOR: 16 '', id: 72059, signal: 4
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: Received CMD_READ_SENSOR_ID_NEW number: 3
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: Received CMD_GW1000_LIVEDATA number: 14
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [040 : 2] 0x0D 'RAINEVENT' = 0 'Rain Event (mm)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [035 : 4] 0x13 'RAINYEAR' = 0 'Rain Year (mm)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [027 : 2] 0x11 'RAINWEEK' = 0 'Rain Week (mm)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [030 : 4] 0x12 'RAINMONTH' = 0 'Rain Month (mm)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [024 : 2] 0x10 'RAINDAY' = 0 'Rain Day (mm)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [021 : 2] 0x0E 'RAINRATE' = 0 'Rain Rate (mm/h)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [019 : 1] 0x22 'HUMI1' = 66 'Humidity 1, 0-100%'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [016 : 2] 0x1A 'TEMP1' = 21.1 'Temperature 1(℃)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [011 : 2] 0x02 'OUTTEMP' = 20.8 'Outdoor Temperature (℃)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [014 : 1] 0x07 'OUTHUMI' = 76 'Outdoor Humidity (%)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [008 : 2] 0x09 'RELBARO' = 1014.9 'Relative Barometric (hpa)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [005 : 2] 0x08 'ABSBARO' = 1014.9 'Absolute Barometric (hpa)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [003 : 1] 0x06 'INHUMI' = 57 'Indoor Humidity (%)'
        10-06-2021 16:03:53 AK Weather Info [1388] Ecowitt Local: [000 : 2] 0x01 'INTEMP' = 22.1 'Indoor Temperature (℃)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: (b) eWH31_SENSORCH1: 100 '%'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: (a) eWH31_SENSORCH1: 0 '', id: 216, signal: 4
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: (b) eWH26_SENSOR: 100 '%'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: (a) eWH26_SENSOR: 0 '', id: 98, signal: 4
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: (b) eWH40_SENSOR: 0 '%'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: (a) eWH40_SENSOR: 16 '', id: 72059, signal: 4
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: Received CMD_READ_SENSOR_ID_NEW number: 3
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: Received CMD_GW1000_LIVEDATA number: 14
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [040 : 2] 0x0D 'RAINEVENT' = 0 'Rain Event (mm)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [035 : 4] 0x13 'RAINYEAR' = 0 'Rain Year (mm)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [027 : 2] 0x11 'RAINWEEK' = 0 'Rain Week (mm)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [030 : 4] 0x12 'RAINMONTH' = 0 'Rain Month (mm)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [024 : 2] 0x10 'RAINDAY' = 0 'Rain Day (mm)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [021 : 2] 0x0E 'RAINRATE' = 0 'Rain Rate (mm/h)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [019 : 1] 0x22 'HUMI1' = 66 'Humidity 1, 0-100%'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [014 : 1] 0x07 'OUTHUMI' = 76 'Outdoor Humidity (%)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [016 : 2] 0x1A 'TEMP1' = 21.1 'Temperature 1(℃)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [011 : 2] 0x02 'OUTTEMP' = 20.8 'Outdoor Temperature (℃)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [008 : 2] 0x09 'RELBARO' = 1014.5 'Relative Barometric (hpa)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [003 : 1] 0x06 'INHUMI' = 57 'Indoor Humidity (%)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [005 : 2] 0x08 'ABSBARO' = 1014.5 'Absolute Barometric (hpa)'
        10-06-2021 16:03:38 AK Weather Info [1388] Ecowitt Local: [000 : 2] 0x01 'INTEMP' = 22.1 'Indoor Temperature (℃)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: (b) eWH31_SENSORCH1: 100 '%'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: (a) eWH31_SENSORCH1: 0 '', id: 216, signal: 4
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: (b) eWH26_SENSOR: 100 '%'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: (a) eWH26_SENSOR: 0 '', id: 98, signal: 4
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: (a) eWH40_SENSOR: 16 '', id: 72059, signal: 4
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: (b) eWH40_SENSOR: 0 '%'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: Received CMD_READ_SENSOR_ID_NEW number: 3
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [040 : 2] 0x0D 'RAINEVENT' = 0 'Rain Event (mm)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: Received CMD_GW1000_LIVEDATA number: 14
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [035 : 4] 0x13 'RAINYEAR' = 0 'Rain Year (mm)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [030 : 4] 0x12 'RAINMONTH' = 0 'Rain Month (mm)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [024 : 2] 0x10 'RAINDAY' = 0 'Rain Day (mm)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [027 : 2] 0x11 'RAINWEEK' = 0 'Rain Week (mm)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [021 : 2] 0x0E 'RAINRATE' = 0 'Rain Rate (mm/h)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [016 : 2] 0x1A 'TEMP1' = 21.2 'Temperature 1(℃)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [019 : 1] 0x22 'HUMI1' = 66 'Humidity 1, 0-100%'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [014 : 1] 0x07 'OUTHUMI' = 76 'Outdoor Humidity (%)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [008 : 2] 0x09 'RELBARO' = 1014.5 'Relative Barometric (hpa)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [011 : 2] 0x02 'OUTTEMP' = 20.8 'Outdoor Temperature (℃)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [005 : 2] 0x08 'ABSBARO' = 1014.5 'Absolute Barometric (hpa)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [003 : 1] 0x06 'INHUMI' = 57 'Indoor Humidity (%)'
        10-06-2021 16:03:22 AK Weather Info [1388] Ecowitt Local: [000 : 2] 0x01 'INTEMP' = 22.1 'Indoor Temperature (℃)'
        10-06-2021 15:57:06 AK Weather Warning [1388] Ecowitt Local: GW1000B-WIFIF90E (FW 1.6.8)
        10-06-2021 15:57:02 AK Weather Info 2021-10-06 15:57:02 AK Weather ver. 4.0.1.35 (4.0.1.59) .NET Framework 4.8.4400.0
        10-06-2021 14:58:17 AK Weather Warning [1106] Ajax-EnvCan: findd(pcpn_amt_pst24hrs) 'MSNG': Input string was not in a correct format.
        10-06-2021 14:58:17 AK Weather Warning [1106] Ajax-EnvCan: findd(max_wnd_gst_spd_10m_pst10mts) 'MSNG': Input string was not in a correct format.
        10-06-2021 14:58:10 AK Weather Warning [1388] Ecowitt Local: GW1000B-WIFIF90E (FW 1.6.8)
        10-06-2021 14:58:07 AK Weather Info 2021-10-06 14:58:07 AK Weather ver. 4.0.1.34 (4.0.1.58) .NET Framework 4.8.4400.0
          Ver 4.0.01.36 - Ecowitt: WH40 battery changed to V / 10
          MikeO3 as I said, battery reporting is total mess, documentation says that WH40 battery only is reported as 0/1 (good/bad) - but it reports eWH40_SENSOR: 16 - which I can assume is 1.6V * 10
          Please also try the AmbientWeather Local for battery readings
            ​Looks like you have been able to sort through some of the mess however.
            Honestly, even with 0 or 1 is a status which can be monitored which is better then none.
            Ecowitt connector:
            Click image for larger version  Name:	image_105821.png Views:	8 Size:	18.9 KB ID:	1501021
            AmbientWeather Local:
            I only see 2 in the log where looks like the WH31 is not there.
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) model = GW1000_Pro
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) Waiting for connection... 0.0.0.0:7777
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) freq = 915M
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) wh26batt = 0
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) batt1 = 0
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidity1 = 66
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) totalrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) temp1f = 69.44
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) yearlyrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) weeklyrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) monthlyrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) hourlyrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) dailyrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) eventrainin = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidity = 99
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) rainratein = 0.000
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) baromabsin = 29.908
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) tempf = 57.9
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) baromrelin = 29.908
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) tempinf = 71.1
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidityin = 55
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) dateutc = 2021-10-07+11:08:16
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) stationtype = GW1000B_V1.6.8
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) POST /data/report/ HTTP/1.1
            HOST: 192.168.0.3
            Connection: Close
            Content-Type: application/x-www-form-urlencoded
            Content-Length:401
            PASSKEY = ------------------------------------------------
            HOST: 192.168.0.3
            Connection: Close
            Content-Length:401
            PASSKEY=-----------------------&stationtype=GW1000B_V1.6.8&dateutc=2021-10-07+11:08:16&tempinf=71.1&humidityin=55&baromrelin=29.908&bar omabsin=29.908&tempf=57.9&humidity=99&rainratein=0.000&event rainin=0.000&hourlyrainin=0.000&dailyrainin=0.000&weeklyrain in=0.000&monthlyrainin=0.000&yearlyrainin=0.000&totalrainin= 0.000&temp1f=69.44&humidity1=66&wh26batt=0&batt1=0&freq=915M &model=GW1000_Pro
            10-07-2021 07:08:14 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) Connected!
            Last edited by MikeO3; October 7, 2021, 06:43 AM. Reason: Uploaded wrong graphics.
              Originally posted by MikeO3 View Post
              Interesting there are 3 devices created however I only see 2 in the log.
              The log is for AW Local protocol, but the screenshot is for Ecowitt (i.e. eWH40_SENSOR)
              WH40 is the rain sensor, WH31 - temperature, not sure about WH26. What sensors do you have?
              [EDIT]
              BTW FYI, for devices which report 0 (good) - I display 100%, and for 1 (bad) - I display 0%
                Yes, I realized I had the wrong picture. That was adjusted. As for the WH26 the internet tells us that WH26=WH32 it appears which was an older model.
                https://help.ambientweather.net/help...splay-console/
                  So Ecowitt protocol shows 3 batteries, but AWLocal - only 2? What devices do you have?
                    Correct 2 on eco_aw_local and 3 on ecowitt
                    Devices:
                    WH31
                    WH26/WH32
                    WH40
                    GW1000
                      Interesting, AWLocal doesn't report one of them, I wonder which one?
                        Not sure. I took the batteries out of the WH31 but the data must be cached. I don't have my tablet nearby to reboot the GW1000 but maybe I can try that later as it's not mounted outside.
                          Playing around with this it appears to be the WH40 which is not reporting with the AWLocal. I changed the WH31 id to CH2 and CH7 and both were found. The WH26/WH32 is also present.
                          10-07-2021 19:42:55 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) P
                          10-07-2021 19:42:55 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) Connected!
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) Waiting for connection... 0.0.0.0:7777
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) model = GW1000_Pro
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) batt7 = 0
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) freq = 915M
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) batt2 = 0
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) wh26batt = 0
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) batt1 = 0
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidity7 = 60
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidity2 = 53
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) temp7f = 73.58
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) temp2f = 76.28
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidity1 = 59
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) totalrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) temp1f = 73.04
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) yearlyrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) weeklyrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) monthlyrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) dailyrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) hourlyrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) rainratein = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) eventrainin = 0.000
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidity = 95
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) tempf = 62.2
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) baromabsin = 29.816
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) baromrelin = 29.816
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) tempinf = 72.0
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) humidityin = 51
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) dateutc = 2021-10-07+23:42:40
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) POST /data/report/ HTTP/1.1
                          HOST: 192.168.0.3
                          Connection: Close
                          Content-Length:469
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) stationtype = GW1000B_V1.6.8
                          HOST: 192.168.0.3
                          Connection: Close
                          Content-Length:469
                          PASSKEY=----------------------------&stationtype=GW1000B_V1.6.8&dateutc=2021-10-07+23:42:40&tempinf=72.0&humidityin=51&baromrelin=29.816&bar omabsin=29.816&tempf=62.2&humidity=95&rainratein=0.000&event rainin=0.000&hourlyrainin=0.000&dailyrainin=0.000&weeklyrain in=0.000&monthlyrainin=0.000&yearlyrainin=0.000&totalrainin= 0.000&temp1f=73.04&humidity1=59&temp2f=76.28&humidity2=53&te mp7f=73.58&humidity7=60&wh26batt=0&batt1=0&batt2=0&batt7=0&f req=915M&model=GW1000_Pro
                          10-07-2021 19:42:38 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) Connected!
                          10-07-2021 19:42:21 AK Weather Info [1452] eco_aw_local: (AmbientWeatherLocal) Waiting for connection... 0.0.0.0:7777
                            Now you have 4 batteries
                              Just purchased the plugin. I also have a GW1100 firmware 2.07 and an outdoor WH32 to start out. Have a couple of WH31 on the way. Sensor and gateway work fine with Ecowitt app on iPhone. Can also see also the sensor data on the ecowitt.net site.
                              Gateway is on different WiFi 192.168.4.57 and Homeseer is on 192.168.2.84.Both are from same router. From my HS machine on 192.168.2.84 I can access the webpage of the Gateway at 192.168.4.57.
                              How do I setup the plugin to access the gateway? Is there a step I am missing where I have to tell the gateway where to send data? Or is there a place to tell the plugin the IP of the Gateway. I see first the post it says Ecowit gateway is automatically found by HS if on same Wifi. What if they are not?
                                My plugin discovers Ecowitt gateway using UDP broadcast on port 46000. I'm not sure how it works across network boundaries, probably it doesn't.
                                Since discovery basically finds the device IP and port and then uses it for communication - I may allow entering them manually - then it should work.
                                You may Google for setting your router to allow UPD broadcast on different network (if it's possible at all).
                                Also, you can try the different protocol:
